Hotend temp cuts out in middle of print
Posted: Fri Aug 23, 2013 3:14 pm
Greetings folks,
Last night I finally got my Rostock Max built and running, all calibrated and ready to go. Didn't even have to change the delta radius after I tuned the endstops.
Told my wife to pick up a lottery ticket on her way home, just like the instructions said...
Anyhow, once I finally got the Onyx up to temp (it seems to top out at about 97c, but my ABS filament was sticking fine at 95 so I ran with that), I started printing the Skeinforge hollow_cube.stl calibration object. Things were going great until about 16 layers in, where the hotend temp just went into freefall until it hit about 30c (a little above ambient temp, it's been warm around here), and stayed there no matter what I told it to do with either Repetier or the LCD control panel.
I had to kill the job, shut down Repetier, shut down the Rostock, wait a while, and turn everything back on for the hotend to respond to heating commands again. The RAMBo fuse was not blown, like I found mention of in another thread, as I was able to start printing successfully again... until just about the same spot, where it happened again.
My gut instinct is either gcode bug or I'm tripping some kind of safety cutout to the hodend temp (I ran it as high as 235-240, but settled for 220 for the second job and it was working fine until it cut out). But gcode doesn't seem like it would keep the hotend from responding at ALL until the printer was powercycled. The hotend is getting full power according to the temperature graphs in Repetier, but it just keeps dropping.
I'm stumped. The Onyx stays hot and keeps responding, it cooks along nicely at 95c.
