when does my LCD come on?
Posted: Mon Jul 22, 2013 4:06 am
by m4r1n5
I've just started calibrating my printer and have been so busy looking at Repetier, that I just noticed my LCD is not showing anything. Is the LCD supposed to come on as soon as I power the printer? If so, how do I isolate the problem between the LCD, Adapter, or board?
Re: when does my LCD come on?
Posted: Mon Jul 22, 2013 8:19 am
by RichW
I have the Rambo 1.1 board with the jumper set to power from the ATX supply. When I power up, the LCD first flashes two rows of white boxes, then briefly indicates the version of firmware loaded in the Rambo board. Then when the boot is complete, the LCD indicates printer ready and shows temps of hot end and bed. At this point, manual control of the machine by pressing and turning the knob is available. This is the same whether the computer is hooked-up or not.
Posted: Mon Jul 22, 2013 11:04 am
by cambo3d
m4r1n5 wrote:I've just started calibrating my printer and have been so busy looking at Repetier, that I just noticed my LCD is not showing anything. Is the LCD supposed to come on as soon as I power the printer? If so, how do I isolate the problem between the LCD, Adapter, or board?
if you have it connected correctly it should at least power on (backlighted). as soon as you apply power to the board. For this purpose it doesn't matter if your using usb power source or the atx power source. If yours is not powering on at all then, something is amiss with your wiring. (connectors plugged in incorrectly or solder job needs more work)
Posted: Mon Jul 22, 2013 11:05 am
by lordbinky
Double check your adapter and cables. I labeled mine wrong when following the manual because I held it the same way as one picture, then labeled it using the positions of another picture. I was really hoping to avoid sharing that one, but if it helps someone.....
Posted: Mon Jul 22, 2013 6:35 pm
by JohnStack
Good feedback all.
I was told that SeeMe is making the ribbon cables shorter due to noise issues.
I recommended a different solution to someone but this might also work:
Flexo Shield
http://www.wirecare.com/products.asp?prodline=FSN
Where you push the ribbon cable and connector through...
Posted: Sat Jul 27, 2013 11:54 pm
by m4r1n5
changed the cables around and fixed the problem
Posted: Sun Jul 28, 2013 4:27 pm
by lordbinky
Hurray! Welcome to the group :lol:
Posted: Tue Oct 01, 2013 10:16 pm
by realcomix
m4r1n5 wrote:changed the cables around and fixed the problem
Thanks to this post my LCD is now working :D
