Y Axis won't reverse in firmware or after wiring switch
Posted: Fri Jun 28, 2013 12:10 pm
I finished assembling my Rostock on Wednesday and set out to getting things moving but my Y axis skate was moving down when I sent a G28. I tried reversing the direction in the latest firmware by switching #define INVERT_Y_DIR and got nothing, then I tried resetting the defaults in firmware and flipping the wiring but still the Y axis only seems to go down.
I also had to set my digipot to near maximum on the Y axis to get any kind of smooth motion out of the skate at all. Initially it would just vibrate in place, the solution to which seems to be more current from searching the forums, but I had to set the digipot all the way up to 240, which seems really high just to get smooth motion. It's not a mechanical issue, as switching the X and Y steppers produces the same vibration on the X axis so the issue lies with the electronics or my wiring, but the Y axis skate runs nicely when connected to the X axis driver so I can't see how it would be the latter.
Any ideas on either issue?
