tricklaser arms printing over sized?
Posted: Sun Jun 09, 2013 8:08 pm
by bplemmons
I'm printing the 25 mm cube oversize with new trick laser arms. it is a new machine and I do have the pulleys set to 20 (plastic)
Do I need to change delta radius in the firmware like I did on the magnets?
Re: tricklaser arms printing over sized?
Posted: Sun Jun 09, 2013 10:13 pm
by Broose
If your prints are slightly oversized on the X and Y axes with the new arms, then you should try increasing DELTA_DIAGONAL_ROD slightly and checking again. DELTA_RADIUS is for dealing with doming on the Z axis (center of platform is higher or lower than outer edges).
Posted: Sun Jun 09, 2013 10:48 pm
by cambo3d
was the magnetic conversion still giving you problems?
Posted: Mon Jun 10, 2013 2:29 am
by bplemmons
It is a different machine...
I haven't seen the heat shield yet, when did you send it Cambo?
Posted: Mon Jun 10, 2013 2:32 am
by cambo3d
bplemmons wrote:It is a different machine...
I didn't, you never sent payment. I figured you changed your mind.
Posted: Tue Jun 11, 2013 12:43 am
by bplemmons
Check your email..... My bad,sorry. Still want it
Posted: Tue Jun 11, 2013 3:49 am
by bplemmons
Posted: Tue Jun 11, 2013 5:15 am
by cambo3d
the firmware listed on the downloads page of the seemecnc website is already setup for 20 tooth pulleys. try that.
that 12.7 diameter isn't relevant for the delta drive 0 type, according to the firmware.
