New to the party!
Posted: Sun Jun 02, 2013 11:09 pm
Hello everyone!
Nice friendly place you guys have here!
I have been looking at the RoStock Max for a bit of time now, but I'd like to know a few things before I buy. This will be my first 3D printer, I know a lot of people say the RoStock is a good challenge so I think I'll give it a try. I'm a Biomedical Engineer who has a bit of experience with electronics and mechanical stuff, enough to get myself into trouble.
A few questions:
- I see a lot of people modifying their printers(different arms, 3mm hot end, different extruder), should I start with the base printer first and then look for upgrades? Or should I purchase them along with the printer?
- I've read that the 3mm hot end and 3mm filament really helps with retraction and less stringing, is this true and would you recommend that upgrade? I was looking at this hot end.
- How accurate/detailed can prints be? I've seen pictures of the Ultimaker print in 20µm layers and the Printrbot print pretty small objects (also with small nozzle), and I was wondering if the RoStock can have similar levels of performance, with lots of tuning and careful assembly. It's unlikely that I'll print that small, but I was wondering if it can.
- How durable is the printer? Assuming it is decently build, how long could would the printer last before something needs to replaced? Or is it more likely that I'll replace something before it breaks to try to get X,Y, or Z?
- If I use the heated bed a lot, would it be good to have an Aluminum heat spread for an even surface temperature? Do I need the layer of glass before putting on tape?
Thank you for your time and for reading my questions!
- X
A few questions:
- X
