Anyone have a Cura configuration file?
Posted: Wed Apr 24, 2013 9:16 pm
Does anyone have a Cura config file to share?
Bill
Bill
Have a look around and join today!
https://forum.seemecnc.com/
I'm just now trying cura and I have this exact problem where it prints into air 15mm above the surface. I see where it moves to z= 15mm, but then it's supposed to go down to z 0.30. This whole start sequence is the default except I edited the G28 to just be one G28 with no xyz parameter. I suspect I need to edit something.sandy wrote:... in preferences did you set your max height to your Z height? When I did that, the Cura slided calibration cube started printing 15-20mm above the surface.
;Generated with Cura_SteamEngine 13.06.4
M140 S79.000000
M109 T0 S232.000000
T0
M190 S79.000000
;Sliced at: Mon 22 Jul 2013 08:32:13
;Basic settings: Layer height: 0.25 Walls: 0.55 Fill: 0
;Print time: #P_TIME#
;Filament used: #F_AMNT#m #F_WGHT#g
;Filament cost: #F_COST#
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 ;X0 Y0 ;move X/Y to min endstops
;G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
M117 Printing...
;total_layers=60
;LAYER:0
M107
G0 F5580 X15.29 Y24.70 Z0.30
;TYPE:SKIRT
G1 F1440 X15.19 Y24.83 E0.01128
G1 X14.99 Y25.03 E0.03007
G1 X13.12 Y26.63 E0.19631
