Just recieved 2 spools of Taulman Nylon 645.
Posted: Sat Apr 13, 2013 12:27 pm
Will be printing some objects using the new Taulman 645 Nylon, will let you guys know how it turns out.
Have a look around and join today!
https://forum.seemecnc.com/
PEEK. It didn't get damaged from the heat, it bumped my print set it off course and come to find out this morning that it cracked it when it bumped the Nylon 618 print I had going. It wasn't melted. Didn't show signs of melting, but it did crack. I know but I needed the heat. I can't wait for my E3D hot end to come in. I think I had my Z height too low, was causing the Hot End nozzle to bump against the print often, lost a lot of prints that way. What could cause your nozzle to bump the print?cambo3d wrote:where did your ptfe tube break?
are u talking about the actual peek? ptfe tube and peek are two different things.
but running your hotend over 240c+, will damage the peek, its just a matter of time. we tried to tell you.
elqisqeyano wrote:PEEK. It didn't get damaged from the heat, it bumped my print set it off course and come to find out this morning that it cracked it when it bumped the Nylon 618 print I had going. It wasn't melted. Didn't show signs of melting, but it did crack. I know but I needed the heat. I can't wait for my E3D hot end to come in. I think I had my Z height too low, was causing the Hot End nozzle to bump against the print often, lost a lot of prints that way. What could cause your nozzle to bump the print?cambo3d wrote:where did your ptfe tube break?
No can do, it broke right at the spot where it meet al block. So no thread was left. I did experiment and put it together with some JB Weld but not sure how much temp JB can handle. It's tough as a rock though. Put it back together and it's sturdy. I'm gonna wait for the new Hot End, not taking any more $ chances.tom10122 wrote:If it is coming from between the peek and al , you can throw some Teflon tape on the threads to seal it, that's what I did.
Thanks Flateric, that is very helpful info. Fortunately I didn't even try it. Didn't trust the JB weld.Flateric wrote:JB weld seems solid but smells funny when it melts. I'm basically saying I tried this with my first hotend and it didn't last more than 1 hour before it melted. I was also printing at much lower temps than you use for the nylon.
Got it, will be adding to my arsenal.Flateric wrote:I honestly trust jb weld with much more and more confidence over many years of use in endless trials. But high heat uses are not a strong point for the product.
Oe product that would do the job for you and you may want to stock in your personal inventory is....
ceramic adhesive by DoneDeal (DD6785). It withstand temperatures up to 1400C. Oddly it is in appearace only very similar to JB weld and JB weld stick.
You are right. I was printing at 245 to 255 for some time, must have become brittle. No worries about that anymore, not with my new E3D all metal hot end. I cranked it up to 350 C just to see, not a damn thing burned. Kept it there for about 30 minutes., without filament o fcourse.oeginc wrote:I think what probably happened is your high temperatures caused the PEEK to get brittle over time. Normal use would not cause your PEEK to break simply by bumping into your print, it's pretty tough.
