bed leveling after Firmware Upgrade v3.4.4
Posted: Sun Dec 10, 2023 10:15 am
by kuper
hello,
I want to calibrate and level the bed on printer ROSTOCK MAX V3.2
the seemecnc manual that I used for the update said not to use G29 run mash and I cannot see the bed map.
Page 12 said to do some configuration on the config file, but I don't know the parameters...
also, I have a z probe problem G32 Error: Z probe readings not consistent.
there is no mesh compensation in the plugins
m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-10-20 16:17:41
I used this manual https://docs.google.com/document/d/1IQf ... 7U9pw/edit
page 14: "At the web browser control “Dashboard”, select “Delta Calibration” from the drop down menu “Compensation & Calibration” (do not run “Mesh”)"
I can not see my bed level...
thank you.
Re: bed leveling after Firmware Upgrade v3.4.4
Posted: Mon Dec 11, 2023 8:48 am
What parameters do you need?
Posted: Mon Dec 11, 2023 1:59 pm
by kuper
I thought the dimension of Rosrock V3.2 but it's working ok
I used this guide to update https://docs.google.com/document/d/1IQf ... 7U9pw/edit
my problem now is the G29 Error: Z probe readings are not consistent
when I do calibration...
do I need to change something in the config file?
post that I asked about it in duet3d forum
https://forum.duet3d.com/topic/34345/bed-level/5
thank you!
Posted: Tue Dec 12, 2023 8:46 am
You'll get that if the heat bed is on during probing or if the nozzle is dirty.
