bltouch probe
Posted: Thu Mar 03, 2022 8:01 pm
by jesse
I dusted off my Rostock Max v1 from Indiegogo 2012. The arms are a bit loose and move a few millimeters if I jostle the effector.
It has Smoothieboard 32-bit electronics.
I've been trying to get auto-leveling to work. Adjusting the screws on each tower doesn't work well enough anymore.
I added a bltouch v3.1 to the Smoothieboard and have the process working. However, it does not level the bed.
G28; #home to max endstops
M280 S3.24; #deploy the probe
G32; #3-point delta calibration
M500; #save results of 3-point[attachment=0]IMG_6681.JPG[/attachment]
G31; #delta grid probing
M374; #save results of delta grid
M280 S7.36; #retract the probe
I mounted the probe in one of the corner holes of the triangular effector. It's about -50mm on the Y-axis, relative to the bed. The maker of Smoothieboard said that the probe needs to be in the same position as the hot-end in the X,Y to get accurate results.
Anyone have advice? The bed is still off about 1mm when moving from X100 to X-100 and Y-100 to Y100.
Re: bltouch probe
Posted: Fri Mar 04, 2022 8:29 am
Oblig: "That thing belongs in a museum!"
Is the firmware you're running have a good auto-calibration system for delta printers? I don't know anything about it.
Re: bltouch probe
Posted: Fri Mar 04, 2022 12:03 pm
by jesse
Yes, the Smoothieboard firmware appears to be trying to do the correct operations. It's the newest firmware version.
Maybe I should measure the distance between the effector and the bed to see if it's parallel. Another idea is to make the leveling screws exactly the same height before trying to auto-level.
Here are the details of auto-leveling on the Smoothieboard:
http://smoothieware.org/zprobe
- GcodeV31.png (220.98 KiB) Viewed 103072 times
I was able to get to the delta leveling grid that saved the SD card.
- notepad++_5OhU8DesjX.png (80.15 KiB) Viewed 103072 times
Unfortunately it's in a serial binary format and I don't have the layout. If I can decode/encode the table, I might be able to put my own measurements to correct for the high/low spots.
Yes, it's the first one I bought. I'm trying to get it working for my Etsy store:
https://www.etsy.com/shop/FantasticGadgets. Then I can sell 9 and 10 inch labyrinths.
Re: bltouch probe
Posted: Sat Mar 05, 2022 9:01 am
I would really recommend you upgrade to the injection molded carriages and the ball & cup arms. The carriages are clear so they'll match the asthetic of the machine and the carriage/arm combination will take a dramatic amount of "slop" out of the system. Reach out to SeeMeCNC and they should be able to supply you with one of the v2 effector platforms that are designed for the ball assemblies - that way you won't have to fab your own.
Doing auto-cal with all three adjustment screws in the same place is the way to go.
Re: bltouch probe
Posted: Tue Mar 08, 2022 9:20 pm
by jesse
I think the autocalibration is needed because my bed is not flat.
I replaced the original MDF wooden fractal star with a solid disc of aluminum, thinking that it would help.
Maybe the acrylic has sagged over time or the aluminum disc is a little raised in the middle.
- IMG_6699.JPG (332.99 KiB) Viewed 103061 times
- IMG_6701.JPG (611.77 KiB) Viewed 103061 times
I put springs under each of the 6 mounting points and that helped enough for 0.5mm layers but not for 0.25mm layers.
Steve from SeeMeCNC sent me a few links to buy the parts to fix the looseness in the arms which will cost about $100 + shipping.
Re: bltouch probe
Posted: Wed Mar 09, 2022 8:50 am
I suspect those springs are your problem. Even the Rostock MAX v0 didn't use springs under the bed - it was nylon spacers.
Re: bltouch probe
Posted: Thu Mar 10, 2022 5:04 pm
by jesse
I turned off auto-calibration and tried just using only the springs. It worked to about 0.5mm layers but not 0.25mm layers.
The maker of Smoothieboard (electronics) said that the auto-level probe is supposed to be in the same spot as the hot end in order to make an accurate delta probe grid. So I may need to 3d print something so that the bltouch can be mounted under the effector temporarily and then removed.
Re: bltouch probe
Posted: Fri Mar 11, 2022 8:19 am
Ah, ok. This is why the SE300 or Duet Smart Effector is such a good choice - the nozzle IS the probe.
I don't know if Smoothie board supports those or not though. (the SE300 uses the same circuit as the Duet Smart Effector.)
Re: bltouch probe
Posted: Fri Mar 11, 2022 10:22 pm
by jesse
Re: bltouch probe
Posted: Sat Mar 12, 2022 6:23 am
Does it work well for you that way?
Re: bltouch probe
Posted: Sat Mar 12, 2022 4:25 pm
by jesse
Yes, it works now, mostly. The printer can make a 9-inch cylinder with 0.25mm layers.
A 10-inch cylinder would be nice, but it doesn't work. Not sure if it's because of the limits of the printer geometry.
The goal was to be able to sell larger labyrinths in an
Etsy store. My Prusa clone maxes out at 8 inches.
Settings added to Smoothieboard electronics "config" text file (below).
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 3.25 # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 30 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.debounce_ms 1
zprobe.fast_feedrate 300 # move feedrate mm/sec
zprobe.probe_radius 127 # where to probe
zprobe.probe_height 74 # how much above bed to start probe
switch.servo.enable true
switch.servo.input_on_command M280 # M280 S7.5 Would be midway
switch.servo.input_off_command M281 # Same as M280 S0 0% duty cycle, effectivley off
switch.servo.output_pin 3.26 # Must be a PWM capable pin
switch.servo.output_type hwpwm # H/W PWM output settable
switch.servo.pwm_period_ms 20 # Set Period to 20ms (50Hz) - Default is 50Hz
leveling-strategy.three-point-leveling.tolerance 0.05 # the probe tolerance in mm, default is 0.03mm
leveling-strategy.delta-calibration.enable true # basic delta calibration
leveling-strategy.delta-calibration.radius 127 # the probe radius
leveling-strategy.delta-grid.radius 127
leveling-strategy.delta-grid.enable true
leveling-strategy.delta-grid.size 15
leveling-strategy.delta-grid.do_home true
leveling-strategy.delta-grid.probe_offsets 0,0,0 # probe offsets x,y,z (Z should always be 0)
leveling-strategy.delta-grid.save true
leveling-strategy.delta-calibration.initial_height 100 # height above bed to stop initial move
leveling-strategy.delta-grid.initial_height 100
The probe is attached to the effector using a set of three M3 screws and wingnuts.
I'm going to print this part on my resin printer next to prevent the filament from buckling in Steve's extruder:
https://forum.seemecnc.com/forum/viewto ... 6&p=100698
Re: bltouch probe
Posted: Sun Mar 13, 2022 12:40 pm
Those labyrinths are great!
You should be able to print to nearly the edge of the glass, even on the "v0" when it's calibrated properly. What problems are you seeing?
Re: bltouch probe
Posted: Tue Mar 22, 2022 5:54 pm
by jesse
geneb wrote: ↑Sun Mar 13, 2022 12:40 pm
Thanks, the manufacturer of the green glitter filament is out-of-stock for a while. I haven't found a replacement.
https://hobbyking.com/en_us/pla-premium ... yking.html
Tried:
