Rostock V2 stops in mid-print
Posted: Wed Nov 25, 2020 8:40 pm
Hi Printers,
I do my printing at the Omaha Maker Group on our Rostock V2. I've been trying to print a Raspi case but the job is suddenly stopping early in the print.
Here are my symptoms.
When the job stops:
What should I do to troubleshoot? Do you have an idea what is going on?
Thanks,
Dave
When the job stops:
- The printer is still powered on.
The print head is not moving and the filament is not feeding.
Matter Control thinks the printer is connected and displays no errors.
The LED display on the front of the printer is dark.
There is only a single amber light inside the case. Usually, there are also 3 or 4 flashing red lights.
The air blowing out of the printer base is not hot.
After power cycling the printer, you can see the LED display is powered, however, no text is displayed.
If I wait 3-4 minutes and power cycle again, the LED display is back and I can cancel the job in Matter Control.
Thanks,
Dave
