Failing Midprint and Corroded Heater
Posted: Thu Jan 18, 2018 9:04 am
The last few prints that I have attempted print perfectly for a while, but when I come back in the morning only half of the model is printed, the printer has homed, and I've got def on nozzle and bed, as well as killed on the LCD. I found what I think is a wiring issue with my heater.
I can easily fix the wiring, but I was wondering if the corrosion around the heater is normal, or if I should just clean it off, or if I should be very worried. The corrosion is very easy to see in the picture I attached. Thanks guys!
