Auto calibration g29 sometimes crashing into bed
Posted: Mon Jan 08, 2018 9:46 am
Hi All,
i just upgraded my rostock v2 to have an accelerometer board and i have noticed that if i run G29 to do the bed calibration from the terminal window it works fine, but then if i put it in the start section of my gcode and hit print, it heats up and starts and then crashes into the bed when doing the x tower (not just a tap but it overshoots and you get a grinding noise).
Any ideas what is going on?
Full setup:
Rambo board
firmware 92.2 (hotend selected at type 3 he280 w/accelerometer)
e3d hot end using this mount https://www.thingiverse.com/thing:2098268
seemecnc acclelerometer board rev 6
ballcup arms and effector plate
original cheapskates with ball end adapters
DIY berd air
slicer is S3d or matter control
i have also tried with astro print and it does the same thing
Full setup:
Rambo board
DIY berd air
