Filament Dryer/Dispenser Revisited
Posted: Tue Aug 01, 2017 2:37 pm
I made a filament storage/dispenser box using a storage box (with foam seal) and dessicants https://www.thingiverse.com/thing:2243469. The humidity would go down to 30% and stay. I thought this was sufficient, as my nylon (Taulman Bridge) prints would come out "good enough."
However, I've been having issues with warping and vertical expansion only on my overhangs (even with supports), and was told by a tech rep at Taulman that this was due to my nylon getting a little too moist (30% too high) and not printing hot enough (I was printing 230-240, he advised to print at 250-255). I tried printing in his range and heard the terrifying steam-pops, signifying that they were too wet.
He advised me to make Taulman's DIY filament dryer http://taulman3d.com/drying-materials.html using a 5 gallon bucket and a trouble-light. It claims it can lower the H% down to 0-10 with a 60W bulb. I tried throwing a trouble-light with a 75 W bulb in my box, it went up to 100 deg F, but only shaved off 5%- down to 25%.
Looking to experiment a little, I took out the light and put in a small dehydrator, Eva-Dry EDV-1100, and boy was that a step in the wrong direction! I think the water it collected in the tank immediately evaporated back into box.
I found on the web a unit called the printdry, which is basically a food-dehydrator with a plastic top.
Does anyone have any experience with Taulman's model, a modded food-dehydrator, or any other simple filament dryer? I saw some posts here from a couple of years ago about using a vacuum pump, but that seems a little too extreme for me, especially if these two models work. I'd like something I can keep in and dispense from, without having to run to the oven every time I want to print.
**Edit* I was also wondering whether anyone's attempted to dry a spool on the heat-bed. I heard 60 deg C for 6 hours works.
