Rambo/Repetier connects ..... then "waiting"
Posted: Mon Feb 25, 2013 5:14 pm
by grayd
I have the rostock plugged into the USB connection, port is live, Repetier software recognizes that the machine is powered up and connected but when I try to run the setup commands in manual control nothing happens. When I hit the connect button in the software it updates from disconnected to connected on screen but has 4 commands "waiting" in the que. Adding the manual commands just ups the waiting counter by one. What have I missed, or better yet, how can I troubleshoot this? Thanks....grayd
Re: Rambo/Repetier connects ..... then "waiting"
Posted: Mon Feb 25, 2013 5:22 pm
grayd wrote:I have the rostock plugged into the USB connection, port is live, Repetier software recognizes that the machine is powered up and connected but when I try to run the setup commands in manual control nothing happens. When I hit the connect button in the software it updates from disconnected to connected on screen but has 4 commands "waiting" in the que. Adding the manual commands just ups the waiting counter by one. What have I missed, or better yet, how can I troubleshoot this? Thanks....grayd
Do you get the splash message when it connects? should be something like FIRMWARE_NAME:Repetier_0.80.......
Have you set the BaudRate to 250000 and selected the correct Comm port in the printer settings?
Posted: Tue Feb 26, 2013 10:29 am
by grayd
Ahh, baud rate was the problem. Apparently the default was too low. Thank you, on to calibration!
grayd
