Does bed heat on first power up?
Posted: Sat May 06, 2017 10:46 am
by sandcrab3
The first time that you turn on power before any firmware is installed, does the bed heat? Just wondering if this is normal, or a problem.
Re: Does bed heat on first power up?
Posted: Sat May 06, 2017 12:45 pm
No, it should not heat up until you tell it to either by running a print or entering a bed temperature in the controller. If it is heating as soon as you turn the bed on, you have a wiring or other problem.
