Is this a temperature, speed, or extrusion problem?
Posted: Fri Mar 10, 2017 5:41 pm
by moody
http://imgur.com/zzADQxT
http://imgur.com/jpSkJoh
Trying to calibrate my Rostock Max v2 with a BondTech QR extruder & E3D hotend to do a better job printing ABS. I have an aluminum bed and PEI and the printer is enclosed. I have no problems with with the first hundred or so layers... It seems that whenever the printer has to print a smaller vertical portion of a print that the layers don't seem to bond as they should and start to look sloppy as if I was over extruding or not running hot enough. I'm confused though because the bottom looks perfect and after the printer gets past the vertical bits and has some longer horizontal sections it goes back to doing fine again which makes me think it may just be trying to print the smaller vertical sections too fast... the example in the photo was printed at Outside Parameters 30mm/sec & Inside Parameters 40mm/sec. 100 degree bed & 240 degree hot-end (I had originally tried it at 235 degrees with similar results).
Any ideas how I can get cleaner prints?
Re: Is this a temperature, speed, or extrusion problem?
Posted: Fri Mar 24, 2017 1:00 pm
by Howler
To me, this looks like a cooling issue. If you watch the print while it does the 'sloppy' part, I bet you would see it push down the previous layers. This is because the previous layer has not cooled enough and is still too soft. I would suggest slowing down to allow more cooling time, or kicking the fan on a little bit (even with ABS, I find it's necessary to sometimes use the part fan for small layers). Or, you can print something else at the same time (effectively slowing down the print and giving more time to cool while it's printing the other piece).
