KISSslicer issue
vrenlos
KISSslicer issue
Post by vrenlos »
Hey all, I decided to give KISSslicer a try last night on a model that's just not slicing properly in Cura. I pulled mhackney's .ini files off of the RMv3 sticky post, and when the print begins, the extruder starts spinning rapidly and non-stop, completely stripping/grinding the filament.
Is there a setting I'm missing/have wrong? I poked around for a while and even compared to mhackney's bandaid model gcode and it looks identical in all the right spots.
Re: KISSslicer issue
Sounds like you have Absolute E set in Printer->Firmware on the Firmware Type drop down. Choose 5D - Relative E
vrenlos
Post by vrenlos »
mhackney wrote:Sounds like you have Absolute E set in Printer->Firmware on the Firmware Type drop down. Choose 5D - Relative E
Thanks for the reply! I tried Relative E as well (which was the original setting) and was getting zero motion on the extruder motor :cry:
I'll give it another go when I get home in a few hours.
Archive.zip
(4.68 KiB) Downloaded 511 times
These should work fine.
vrenlos
Post by vrenlos »
I haven't found the actual difference from last night and I've got some material tweaking to do...but I'm printing! Thank you, good sir!
Great, please read the link in my signature, it will help.
Return to “RostockMAX v3”
