Curious Cura behaviors
Posted: Sat Feb 11, 2017 6:42 pm
OK - based on some of the advice offered by illustrious members of the forum, I'm trying to move away from Simplify 3D. Its actually worked well for me so far, but I'm up for a challenge. So I got Cura and have 2.3.1 up and running.
I have two issues/questions.
1 - I get "banding" (for lack of a better word.) I haven't had this problem in S3D so I think its the math coming out of Cura. It occurs roughly every 100 layers. The whole model appears to be offset by maybe 0.05 - 0.075 mm. Then after another 100 layers it shifts back giving me a wierd banded surface. I thought I'd ask before spending the whole weekend troubleshooting. Maybe someone else has seen it and knows what it is from the description.
I'll need to rotate the models and see if the banding still occurs in the same direction. Move it around on the plate and see if it affects it. But maybe someone can tell me what I screwed up on the install and I can correct it.
2 - Cura will not save my filament profiles. I'm not sure what I'm doing wrong - but I put it in the Material Settings. Then on restart its gone and I have to put the material information back in.
Thanks for any help.
DK
DK
