Heating and cooling options for Eris?
Posted: Wed Feb 01, 2017 11:06 am
				I have been playing with a Ber-Air cooler on my Eris, and the results have been great.
A few things though...
I have to run the Berd-Air at a pretty low power because the Eris' hot end temperature easily drops when there is any external cooling fans.
Is it practical to increase the heating capabilities of the Eris, perhaps replace the single heating resists with a 40 watt cartridge?
Also, I am currently manually turning the Berd-Air on after the first layer or so, and off after the print is finished.
The Eris only has one fan to cool the extruder and the layers, so I don't know if it isn't simply running full power all the time.
Assuming I put in a power adapter so as not to draw too much current from the mini-Rambo, where would I hook up the Berd-Air so I can use the slicer to turn it on at a particular layer and off when the print finishes?
