Aluminum Cyclops Water Cooling :D
Posted: Sun Jan 29, 2017 6:27 pm
Hi, so at first I wasn't sure i could make my own water cooler. But after talking to McHackney and others about it i decided that what i really wanted was dual extrusion water cooling, so it made little since to invest in water cooling for an E3DV6, when what was really needed was a water-cooled cyclops. I did some research and found a nylon version i could print, but unfortunatly after i got it printed (and that was quite a hassle, nylon is difficult) i realized that the dude that designed it ended up saying it leaked after a few weeks. Bummer
. I looked at his posted and saw that he made an aluminum water cooler, and while there weren't any plans, after careful inspection of how it was made i figured it out. Cross drilled water coolers have been popular since the early 2000s but this is the first i have heard about it
. Luckily i do possess a drill press and a table saw. ONWARD!
[img]http://i.imgur.com/3FgmCBy.jpg[/img]
First step was to turn a big block of aluminum to a 30mm x 30 mm square. 30.14mm is close enough
BTW, i was going to buy the cheap blade till i read more than one review that indicated in broke into several pieces after a few cuts.. O.O
[img]http://i.imgur.com/eoUTKOp.jpg[/img]
I saw some X-Y vices, but it seems no matter what price range i looked at (well, sub $200) all had the same reviews about it being not precise and wobbly, so opted for just some a regular vice. It worked fine...
[img]http://i.imgur.com/yJ4Feli.jpg[/img]
Got it lined up ready for the first drill bit.
[img]http://i.imgur.com/YZK0IiI.jpg[/img]
hole number two... now, for the third hole!
[img]http://i.imgur.com/XXWCOUk.jpg[/img]
I CAN SEE THE LIGHT! Thats when i knew i was on the right track....
[img]http://i.imgur.com/VCjU3Jn.jpg[/img]
I drilled some mounting holes. The first time i accidentally drilled it with the heat block turned upside down so i drilled through the cross hole
Oops. I kinda got flustered so i forgot to take a lot of pictures after this point. But, i made it again!
[img]https://i.imgur.com/xpl4cVx.jpg[/img]
bumpa-da-ba, The finished result. I was able to tap the holes and it went together nicely. I used epoxy around the water-inlets and cross-drilled screw to ensure no leaks. Then, i used some thermal adhesive epoxy to join the cut-off chimera to the heat block and finished it off with some screws, because the other guy had screws. Though, from experience i think the epoxy itself would have been just fine. I used to to glue a heatsink onto my berdAir it it seems to be very strong.
[img]https://i.imgur.com/KnIUA8z.jpg[/img]
[img]https://i.imgur.com/ZnuaRaB.jpg[/img]
[img]https://i.imgur.com/qjtERt1.jpg[/img]
Not perfect, you can see some apprentice marks, but all in all, a fun project. Just got to figure out how to mount it
This is the link to the original idea:
http://www.thingiverse.com/thing:1375628
It's in the comments section.
