Simple Question
Posted: Sun Jan 22, 2017 11:57 pm
				This is a quick question, I'm working on assembling the hot end for my RMax v3. I've read the instructions a few times and the comments. And perhaps I'm being a bit too literal but I have to ask before I make an assumption that could potentially break something or cause me to have to take it apart to correct.
In Step 1 - HE280 Assembly http://seemecnc.dozuki.com/Guide/Step+1 ... ssembly/45
Am I looking at the right part? Either way I need a bit of guidance as to what I'm looking to "test fit" and what I'm looking for to "pass" that test. does it need to seat all the way down, just fit in the whole a bit?
Thanks in advance!
Matthew (TaggedZi)
I've found the heat sink and the heat break and I found a black plastic tube that is about 4.3mm (diameter) I'm assuming it is the 4mm PTFE? But I don't see it in the diagram to confirm, and I don't see what I'm testing the fit too? It doesn't seem to fit IN the heat break (Larger end), without cramming it and the fit is just off enough that I want to make sure I'm getting it right.Step 12 — Preparing the Heat Sink / Break
Locate the HE280 Heat Break and test fit the 4mm PTFE tubing. The tube should insert and fully seat.
Thanks in advance!
Matthew (TaggedZi)
