Really rough benchy wall corners (blobbing?)
Posted: Fri Jan 13, 2017 3:03 pm
[img]https://i.redd.it/nu7amaq0bj9y.jpg[/img]
I've been trying to get a decent print from my Rostock Max v2, using a spool of clear PETG. The stringing is pretty bad, and the wall corners are very bad (the blue highlights in the benchy). In an effort to fight stringing I upped the retration a bit from defaults, and dropped the temp down to 240 as per the range in http://airwolf3d.com/2015/12/05/3d-prin ... nd-tricks/
This one was printed with support material, cut with Simplify3D, .2 layer height, all default settings for retraction and fan. Rostock Max v2, upgrade E3D All-metal v6 HotEnd Full Kit 1.75mm Universal, .4mm nozzle. SainSmart PETG 3D Printers Filament.
I don't mind the stringing, I can pull those off. I slightly mind the blobs (bow of ship) and really mind the edges, when I try to print a fidget w/ hinges it completely binds up. You can see near the top-right of the blue area the edge is ok, but then as you go down from there, it looks really bad.
Open to any tips, will post follow-ups as it improves!
