E3D is now selling nickel-plated copper heater blocks and nozzles + hardened hobbed bolts
Posted: Thu Dec 29, 2016 12:58 am
				Blog post: http://e3d-online.com/Blocks-Nozzles-Hobbs
Got an email about this last week. Shipping from UK was quite prompt. Filastruder didn't have these in stock at that time, but I suppose they will sooner or later.
Nozzles in many sizes
Heater blocks
Hardened hobbed bolt
Copper conducts heat better than aluminum, which they say may slightly increase heat-up times and improve fine temperature control. (I prefer hand-tuned PID... works great for me.) The heater blocks and nozzles are also rated to 500 C, whereas aluminum begins to soften at 350 C. Additionally, the nickel plating makes the surface more resistant to accumulations of plastic, yielding (in their words) "exceptionally smooth top surface layers" and "clean accurate perimeters". I'm looking forward to trying these with PETG, which does have a tendency to accumulate on their brass nozzles for sure. I'm just waiting for some extra V6 heat sinks and fan kits to arrive from Filastruder.
They claim that the nickel plating (which is done on the entire surface, including the inside of the nozzle bore) is less sticky, and will therefore flow more easily. I wonder what effect, if any, this will have on retraction. They say that it will reduce blockages with TPU and other filaments that like to degrade, because the gunk won't stick to the inside the nozzle. It will supposedly work better with filled materials, although I don't know how well that plating would stand up to abrasive materials like metal-fill or carbon fiber.
Speaking of abrasive material, they are selling hardened steel hobbed bolts (the thing that grabs and pushes the filament in the extruder). They have a photo of a non-hardened hobbed bolt that has been chewed up by metal filament, making it less effective and more prone to skipping. The hardened version should last much longer when printing with such filaments. This is a drop-in replacement on Titan extruders. The bolt is shipped pre-fitted into a delrin gear, which I suppose you could cut off and just use the bolt on another extruder, although I don't know what the inner or outer diameters are or whether the bolt has provisions for grub screws.
I also saw that they have an experimental 0.15 nozzle. They recommended using MG94-ABS, PC-ABS, or PMMA (which I think is acrylic) filament, so I picked up a spool of PMMA as well.
Heater blocks
