Planetary gearbox: is it worth it?
Posted: Fri Dec 16, 2016 1:09 pm
Hey guys! Excited to report that I have successfully updated my Rostock MAX v1, which I purchased at a Maker Faire in 2013 before I knew anything about 3D printing, and which never really worked properly, to what is effectively now a Rmax v3 with molded cheapskates, ball joints and an HE280 hot end assembly (for which I'll hopefully soon be posting some pics of a sweet fan shroud + LED lighting assembly I designed the other day). I'm stoked because for the first time in pretty much ever my Rostock is reliably cranking out quality prints and getting better by the day. Makes me glad I kept it - there have been times in the past few years when I've been tempted to write it off as a failed experiment, and now I'm really glad I decided to hold onto it instead.
HOWEVER I am now scratching my head over one of the final outstanding issues, which is that even at moderately low speeds my extruder seems to be skipping steps pretty frequently. This is obviously affecting my part quality, and I would also like to be able to push the limits for how fast the HE280 can melt filament without being limited by inadequate extruder torque. I am considering upgrading to a stepper motor with higher torque, like this one:
http://www.omc-stepperonline.com/gear-r ... -p-40.html
But I am also open to suggestions if there are other things that I can do to try to mitigate this without spending even more money in addition to what I just spent to get the printer up to date. Here are some specs on my system as it currently stands:
Chassis: Rostock Max v1
Delta arms: Latest molded carriages & ball joint assembly from SeeMeCNC
Controller: Rambo v1.1b
Firmware: 0.92.2
PSU: 12v ATX from OCZ rated at 600w
Extruder: New EZR extruder from SeeMeCNC mounted to original direct-drive Nema 17 from Rmax v1, now outfitted with a heatsink
Hot End: HE280 with 0.7mm SS nozzle
Preferred mode of printing: SD card
Preferred materials: PLA, Carbon Fiber HTPLA from ProtoPasta, NinjaFlex
Preferred Slicer: Simplify3D (seems to get a bad rep around here, but I'm happy to defend it - I do product design for a living and in my circumstances, where the cost of troubleshooting gets expensive quickly, $150 is a small price to pay for the quality, consistency and high level of professionalism evident in the engineering behind that software).
Would love to hear your suggestions for how to maximize performance from the extruder. Happy Holidays!
Firmware: 0.92.2
