Changing speed settings doesn't seem to make any difference?
WLJayne
Post by WLJayne »
Hi guys,
When I change the speed settings in mattercontrol, the only one that seems to be different is non print moves. Sometimes when I bump things like the perimeter speeds up to 300mm/s or so the time estimation is longer, and the perimeters are certainly not printing at that speed. What's going on?
IMBoring25
Re: Changing speed settings doesn't seem to make any difference?
Post by IMBoring25 »
What are your cooling settings?
I'm wiling to bet your print speed is at odds with your minimum layer time setting. :)
WLJayne
Post by WLJayne »
Cooling is at 60% layer fans, unsure about the hotend fan. Where can I change the minimum layer time setting?
EDIT: Got it! I'll test it.
Return to “RostockMAX v3”
