DeltaCon wrote:Maybe your PSU hickups (or even your mains...). Try to monitor the power served by the PSU, if that dips around the time of a reset, that's probably it. I had the same issue, but it wasn't resetting, it was shutting down completely. I RMA'd the PSU and the second one I got works just fine. I do not think it is a Rambo thing (yet).
I've had an issue that was similar, where it was the physical reset button on the rambo slowly degrading despite not being pressed. I hesitate to mention it, as it's an isolated issue from what I know, and it's just an utterly bugnuts one. However, I would see if the reset switch seems to click properly on the board. If not, contact Ultimachine/seeme for a replacement or repair, or if you are rather confident, desolder it (I do not recommend this, as it will likely void any warranty from Seeme or Ultimachine)
