Bed resistor?
Posted: Fri Nov 18, 2016 12:43 am
Hey everyone,
Hope all of you are experiencing perfect prints with perfect temps and no other problems! Haha, anyways, I have been looking through these forums for an answer, but it seems I may be the first one to ask. What is the actual name or typr of resistor that goes on the bottom of the Rev 8 heat bed? I think that could be the problem when my temps go DEF. The reason I say this is because all day, literally ALL day I have been trying to find the source to my temps/thermistors failing and when I was applying the Kapton tape back to secure the bed wires (I had given up for the night), I accidentally moved the resistor and like magic, the temps showed up on the LCD and no more DEF. I will definitely replace the resistor as I believe that was the culprit all along. I guess I just didn't think that had that big of an impact on the entire operation. What do you all think? I am open to ideas.
also, I have replaced the bed thermistor two times today with new ones, didn't remedy the DEF. Also using a brand spanking new HE from Seemecnc (factory assembled for warranty). Just thought that would be relevant to share.
thanks in advance and I hope that if someone else is having the same issue, that this thread can help them as well.
