First Fail on V3
Posted: Wed Nov 16, 2016 3:40 pm
So this happened last night.
I've been printing on bare glass with no problems up till now, but I guess it's time to look at installing that FabLam I bought. I was printing a geared cube from Thingiverse (http://www.thingiverse.com/thing:213946/#files). The individual gears and center-piece were all still adhered, so my guess is that one or more of the small pins in the lower right let loose from the bed and then it was off to the races. Too bad as I started the print and watched the first 4-5 layers go down before heading to bed. This couldn't have happened more than 10 minutes after I left the room...
After removing the bird's nest, you can see on the gears how the last layer somehow got offset about 12 mm in X and 5 mm in Y before going completely zonko.
My real question is, "what's the best way to clean a hot end that looks like it was dipped in a bucket of plastic?"
I've warmed up the hot end and been going at it with a combination of tweezers, small needle nose pliers, and leather gloves, but it's still pretty bad. I'm worried about the metal tools possibly shorting across the heater leads and whatnot, so I've been working in cycles--heat it up, turn it off, and try to clean chunks off while it cools.
Is there a solvent that just dissolves PLA? If so, I'm ready to buy a bucket...
