HE280 Upgrade / Repetier .92 upgrade causing repeated shutdowns???
Posted: Wed Sep 28, 2016 5:16 pm
I've seen a couple possible solutions to this that I honestly haven't tried yet. Thought I could hopefully save some putzing around and a few hours of my life by asking here first.
Last night the HE280 showed up at my door and like a little kid at Christmas I started building it that instant and installed it later that night. As per the instructions I also upgraded the repetier firmware upgrade to 0.92.
The auto calibration worked flawlessly.
(Well, aside from my bowden getting caught up between an axis and an end stop every time it homes from the platform. Anyone have any suggestions for keeping that from happening?)
The next thing I tried was running some PLA through it, I used repetier-host to set the hot-end temp and squirt some goo through it. Worked fine.
It wasn't until I I was trying to figure out why I couldn't control the extruder w/ repetier-host that I encountered this issue. (I figured out that it doesn't turn on until it's at temp). I discovered that if I choose 'Preheat PLA' from the front panel the printer shuts off. Consistently, at anywhere from 15-20 seconds into heating up at which point I have to cycle the power switch to get it turn on again. Basically it's when it starts to heat up the build-platform + the hot-end.
This issue didn't exist until after the repetier upgrade / he280 install.
I'm running an original v2 built from kit w/ the 'stock' generic modded ATX power supply, stock cheapskates, stock arms, stock rambo board, etc, etc...
Are there some undocumented features/firmware settings/installation steps I need to know about?
