HE280 Wire Harness
Posted: Wed Sep 21, 2016 12:32 am
So, I didn't get the whip, for some reason I thought it would be easy enough to line up without it. It is not as easy as I had hoped.
Does anyone know what the upgrade wire relationships are for the HE280 from a stock Rostock?
8 Pin from Top to Bottom
Thermistor Signal (Positive Thermistor Wire?)
Int PIN (?) - No Idea what wire this should be
SDA( HEAT1 Black ISC2)
SLA(HEAT1 Red ISC1)
Common Ground (?) - Is this the negative Thermistor wire / FAN0 Black?
HE Switched Ground (HEAT0 Black 18 GA)
+12V Constant (HEAT0 RED 18 GA)
Part Fan ( FAN0 Red? )
Anyone know for sure?
The guide is a bit vague, it assumes you bought the whip. (I am seriously thinking of just waiting on it.)
SLA(HEAT1 Red ISC1)
