New Enclosure, Fire Prevention, and PEI/Aluminum Spreader
Posted: Wed Jul 13, 2016 8:00 pm
[img]http://s31.postimg.org/f1wxrkhsr/image.jpg[/img]
Overview of my updated Rostock. I think a Duet + FSR's are the next major upgrade... perhaps in september. Cyclops dual extrusion right around the same time (even though i havn't had a need for it, i liked it on my old prussa)
[img]http://s31.postimg.org/xircidxqz/image.jpg[/img]
Heat controller and the bondtech extruded moved up outside of the enclosure for cooling. Still gets a little hot, but havn't had any problems. I havn't tried ninjaflex filament yet, but I don't see a huge different between the stock extruder and the bondtech using PLA/ABS. I bought it when i bought the printer.. i'll probably just use the stock extruder as the second one, once i go dual extrusion.
[img]http://s31.postimg.org/aikp61zx7/image.jpg[/img]
I was worried about loosing my tool cadies, but the only tool i need fits right on top
[img]http://s31.postimg.org/zd4704krf/image.jpg[/img]
I know there are some high - tech relay driven things that can turn off a printer, but i decided an extinguisher makes the most sense. Shutting off the printer after detecting smoke is too late. This will put out the fire. (hopefully). I drew up a mount in autocad, printed it out and it worked the first time! (had to make some manual adjustments with a pair of dikes). Also, my ceramic socket for a 150w heater. It gets the enclosure up to 48c in about 15 minutes, it doenst seem to fully get to 50c but its close enough, right?...
[img]http://s31.postimg.org/npa55kvmj/image.jpg[/img]
So far the leds have been fine operating at the higher temp, but if there is a problem later on i'll probably switch them out to something more enclosed. I think also i might need a fan at the top to circulate the air downwards, because it seems like most of the heat is concentrated at the top. I put the thermometer through the wiring harness sleeve about 3/4 the way down... and its probably a lot hotter at the top of the machine than it is at the bottom. So i think a little something to push the air down might help, without causing too many issues with warping?
[img]http://s31.postimg.org/pv4g02z2z/image.jpg[/img]
The aluminum sheet from Trick Laser was completely flat with a smooth finish. I like it. Although i do miss those lonely seemecnc eyes starting up at me
I also put on the sheet of PEI. Went on pretty smoothly, its a lot easier to put on that an iPhone screen protector
[img]http://s31.postimg.org/uv6hlru3f/image.jpg[/img]
This shows the corners and the hinges. I hadnt ever used acrylic solvent "glue" before so i decided more was better and got a bit too much on the glass so it looks less than professional, but it WORKS and is a strong bond. I have a feeling i'll end up doing something to block to two gaps in the front on either side of the door.. but for right now i'm gonna PRINT ALL THE THINGS!
