Anyone using FSR's with their duet? Can you share your bed.g file?
Posted: Mon Jun 20, 2016 2:05 am
I'm a bit lost as to where I should set the probe points and such so I wanted to see if any of you had already done the work
Have a look around and join today!
https://forum.seemecnc.com/
; Auto calibration routine for delta printers
; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
M561 ; clear any bed transform, otherwise homing may be at the wrong height
G31 X0 Y0 ; don't want any probe offset for this
G28 ; home the printer
; bed.g file for RepRapFirmware
; 13 points, 6 factors, probing radius: 100, probe offset (0, 0)
G28
G30 P0 X0.00 Y100.00 Z-99999 H0
G30 P1 X86.60 Y50.00 Z-99999 H0.05
G30 P2 X86.60 Y-50.00 Z-99999 H0
G30 P3 X0.00 Y-100.00 Z-99999 H0
G30 P4 X-86.60 Y-50.00 Z-99999 H0
G30 P5 X-86.60 Y50.00 Z-99999 H0
G30 P6 X0.00 Y50.00 Z-99999 H0
G30 P7 X43.30 Y25.00 Z-99999 H0
G30 P8 X43.30 Y-25.00 Z-99999 H0
G30 P9 X0.00 Y-50.00 Z-99999 H0
G30 P10 X-43.30 Y-25.00 Z-99999 H0
G30 P11 X-43.30 Y25.00 Z-99999 H0
G30 P12 X0 Y0 Z-99999 S6
G91
G1 S1 X170 Y170 Z170 F15000 ; go part way up to speed up homing, endstops activated just in case
G90
G28 ; Home the printer again so as to activate the new endstop adjustments
btw I recommend you removed that final G28 homing command. It hasn't been needed for a long time, and by not re-homing, you allow the bed probing to correct for any inconsistency in the homing switches.lignumaqua wrote:I'm having good success with this on a Rostock Max V2 with a Duet and FSRs. It was generated using the tool dc42 links to. You can go to a larger diameter but I found that the bed wasn't flat enough for consistent results too near the edges. Note I have one H value. You likely want to get rid of that.
; Auto calibration routine for delta printers ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g. M561 ; clear any bed transform, otherwise homing may be at the wrong height G31 X0 Y0 ; don't want any probe offset for this G28 ; home the printer ; bed.g file for RepRapFirmware ; 13 points, 6 factors, probing radius: 100, probe offset (0, 0) G28 G30 P0 X0.00 Y100.00 Z-99999 H0 G30 P1 X86.60 Y50.00 Z-99999 H0.05 G30 P2 X86.60 Y-50.00 Z-99999 H0 G30 P3 X0.00 Y-100.00 Z-99999 H0 G30 P4 X-86.60 Y-50.00 Z-99999 H0 G30 P5 X-86.60 Y50.00 Z-99999 H0 G30 P6 X0.00 Y50.00 Z-99999 H0 G30 P7 X43.30 Y25.00 Z-99999 H0 G30 P8 X43.30 Y-25.00 Z-99999 H0 G30 P9 X0.00 Y-50.00 Z-99999 H0 G30 P10 X-43.30 Y-25.00 Z-99999 H0 G30 P11 X-43.30 Y25.00 Z-99999 H0 G30 P12 X0 Y0 Z-99999 S6 G91 G1 S1 X170 Y170 Z170 F15000 ; go part way up to speed up homing, endstops activated just in case G90 G28 ; Home the printer again so as to activate the new endstop adjustments
Thank you, will do!dc42 wrote:btw I recommend you removed that final G28 homing command. It hasn't been needed for a long time, and by not re-homing, you allow the bed probing to correct for any inconsistency in the homing switches.
