Question about retracts
Posted: Wed Mar 23, 2016 5:07 pm
I have a question that just puzzles me while printing out a iPhone case:
During the printout the print head nozzles relocates a couple of times to start printing again. So far so good. I observed that there was some oozing and found out that there was no retract of the filament done. Even worse, the print head didn't lift up for 0.3mm while moving and just sort of scratched over the surface. This made resulted in some noise during movement over the printed 'lines'.
When looking at the nozzle movement code in Mattercontrol, I can clearly recognise that there was no retract and that the head stayed at the same layer hight while moving that far.
Question: Is this a fault of the slicer engine (Matterslice) or is this just fact?
Here a picture of what happened and this green line also showed on the actual print out as a scratch. (I've marked it with a green arrow)
Why wasn't there a retract?
Thanks for clarifying!
*John*
*John*
