Mhackney's Rostock Max
sLpFhaWK
Re: Mhackney's Rostock Max
Post by sLpFhaWK »
oh I was going to start a new thread, but I stumbled on yours and saw you were in MA so I wanted to see if you wanted to help assemble it =) I am chatting with JJ now on the live chat, and he told me to order the new injection molded cheapskate carriages, and ROSTOCK MAX BALL-CUP DELTA ARM KIT.
I'll get that topic up, should I post it under troubleshooting ya think?
No, put it in this The Build Zone.
I may be able to help at some point but no promises. I'm stretched pretty thin right now. But if you can make a trip to me that saves me some time and I have pretty much every tool, wire, connector, etc that might be required. Oh, and a complete CNC machine shop.
And the injection molded cheapskates and new ball cup delta arms are THE way to go! Tell JJ I said hello.
sLpFhaWK
Post by sLpFhaWK »
Oh I would definitely go to you for help, I wouldn't make you travel to me seeing you we're gonna do me a favor =) full CNC shop, nice. Built a DIY kit yourself?
I've built them from scratch starting with Grizzly or MicroMark machines. A 10x22 lathe, a G0704 mill and an X2 mill and a 2x3 scratch built router. Plus all the printers I have! You can find me on the CNCZone with the mills.
IMBoring25
Post by IMBoring25 »
The new cheapskates and LED PSU were rolling changes. He said he got this from a third party as a partially completed kit, so it's unsurprising it's an older kit.
It's a "near-transition" kit. The vent holes are later-model v2 - just prior to the injection molded carriage update. It blows my mind that the original owner glued the belts in. *facepalm*
Realistically, I'd dump the carriages & arms and get the updated carriages and ball & socket arms. You'll be a lot better off in the long run.
The v3 shares no melamine parts with the v2. It's a completely new chassis design.
Gene, yup he bought the new carriages and arms yesterday. I offered to help assemble at my place - IF and only IF he removes all the paper from the melamine parts!
Well, after years of faithful and almost daily service, the 24V power supply driving my Onyx gave up the ghost. It turns on, outputs 23V (as I adjusted it) but as soon as the Onyx load switches on, it dies (the LED goes out, no output). Unplug-replug resets it.
I've swapped it out with a new 24V supply and it is doing fine so I've eliminated issues with the SSR, wiring and Onyx.
sLpFhaWK
Post by sLpFhaWK »
Hey guys, quick update. I built the printer started yesterday and finished tonight. I emailed you Mhackney a few days ago asking if you were free today, but I never got any reply back so I just thought you we're busy which is why I started yesterday.
Took me probably 18ish hours I would say start to finish. Because of the older kit, I did end up ordering the new cheap skates, and arm upgrades now included in the v2 and I must say they are very nice. I yanked the psu and my e3dv6 from my 1st printer I wasn't using much seeing I am planning a rebuild, and I ordered an aluminum mount for it as well from 713maker.com and it came out really well.
The hardest part of the setup process was mattercontrol, that software is terrible. Tomorrow I hope to use simplify 3d as it's my slicer of choice.
Here is a link to a 3 image album just to show her off, I'll post my own thread so I don't spam Mike's anymore. =)
http://imgur.com/a/NRpwz
aerouta
Re: Updating to Duet WiFi electronics
Post by aerouta »
mhackney wrote:I decided to try David Crockers Differential IR Probe on my Rostock. Currently it is fitted with FSRs but I can leave those in place and mount the IR probe and be able to do head-to-head comparisons. I've also converted the electronics to a pre-production Duet WiFi board that I was sent to test. So far it has been really nice, I haven't completely tested the effects of all the micro step options (up to 128 micro stepping). Here are some photos:
original 0.6 Duet before replacement:
[img]http://mhackney.zenfolio.com/img/s4/v63 ... 8580-3.jpg[/img]
the new Duet WiFi waiting in the wings for its turn in the spotlight:
[img]http://mhackney.zenfolio.com/img/s11/v2 ... 4572-3.jpg[/img]
installed using the same mount - the form factor is identical across the Duet .6, 0.8.5 and WiFi versions
[img]http://mhackney.zenfolio.com/img/s11/v3 ... 2837-3.jpg[/img]
and all hooked up ready to run
[img]http://mhackney.zenfolio.com/img/s3/v40 ... 2394-3.jpg[/img]
and here is the IR Probe mount I made for the Trick Laser effector and my modified water cooled E3D V6 hot end with Volcano. The clearances look closer in the photos, I'll put Kapton tape on the backside of the board t be safe but I think I'm ok. The mounting system can slide up and down (slots in the printed red mount) and forward back (a slot in the mounting ear on the red mount) so I can fine adjust the probe position.
[img]http://mhackney.zenfolio.com/img/s7/v15 ... 8827-3.jpg[/img]
[img]http://mhackney.zenfolio.com/img/s12/v1 ... 7341-3.jpg[/img]
Just purchased the Duet Wifi, along with your recommended FSR kit. I was looking through your thread to see if you discussed the FSR some more and I saw that you may have switched to an IP probe? How is this working out for you? Do you prefer an IR probe to FSR? Also any tips regarding the Duet Wifi vs the 0.8.5? Have you played with the micro step options?
No, I am CONSTANTLY testing new things so of course I've tested an IR Probe. I have it hooked up on my V1 along with FSRs. But I use FSRs to actually calibrate on the V1. I was not able to use the IR probe with my PEI surface. Firstly, you do have to paint the back black - which I did. But unfortunately, the method I use to repair my PEI with CA glue affects the IR reflectivity and leads to erroneous probe results. So I use FSRs to calibrate.
Yes, I use the microstepping. Right now I am at 16 microsteps. I want to do some more experimentation at higher microsteps but I will do that on my MAX Metal with .9° steppers.
Here are the STL files for the IR Probe mount and Duet (any version) mount.
IR Probe.stl.zip
(9.43 KiB) Downloaded 767 times
DuetMount.zip
(23.71 KiB) Downloaded 669 times
aerouta
Post by aerouta »
Thanks for the info.
Another question... I just purchased the Bondtech QR, couldn't find much information on your installation of the Bondtech extruder on your V1. Do you have this covered somewhere? Did you use a similar installation that you showed on the V3?
There's this: http://sublimelayers.blogspot.com/2016/ ... g-for.html
And in my v1 max build thread is info including the mount I designed. The V1 mount is different than a V3. I think it will work on a V2 also. The V3 mount I posted on my blog is specific to V3.
Oops, this is my V1 thread! I guess I wrote about it here: http://forum.seemecnc.com/viewtopic.php ... h&start=25
But let me know if there's something else you are looking for.
Return to “The Build Zone”
