If you can convince Matt to make more, even as a special request, I'm perfectly happy to let him have commercial rights to the design (For attribution only), but I've got no mills to call my own. I do appreciate the vote of confidence in my design skills though. I went ahead and put them on Repables in case you want to print a test set or work with a different manufacturer (STL, STEP, and f3d files). You can find them heregeneb wrote:I think someone needs to start volume production of those awesome looking FSR mounts. *coughs*
You are correct. Certainly in the UK there would be one or more circuits for power and one or more for lighting, almost invariably one of each per floor in most houses. Those would be rings, so each point is fed from two directions. Then a few other circuits for the cooker and the water heater and so on. The power ring circuit that feeds the wall sockets is wired with 2.5mm2 conductors and fused at 30A. Each individual socket has a maximum draw of 13A, about 3kW. All sockets in the bathroom have internal isolation transformers and only have two pins, but they are on the power ring circuit.Xenocrates wrote:(And indeed, I've heard of some circuit designs where there are only a small number in the house, typically lighting, kitchen appliances, bathrooms and wall outlets)
Here's another question, since you seem to know UK wiring. Breakers or fuses, and why?rurwin wrote:You are correct. Certainly in the UK there would be one or more circuits for power and one or more for lighting, almost invariably one of each per floor in most houses. Those would be rings, so each point is fed from two directions. Then a few other circuits for the cooker and the water heater and so on. The power ring circuit that feeds the wall sockets is wired with 2.5mm2 conductors and fused at 30A. Each individual socket has a maximum draw of 13A, about 3kW. All sockets in the bathroom have internal isolation transformers and only have two pins, but they are on the power ring circuit.Xenocrates wrote:(And indeed, I've heard of some circuit designs where there are only a small number in the house, typically lighting, kitchen appliances, bathrooms and wall outlets)
