Prometheus Hot End: Customizable All Metal Hot End!
Re: Prometheus Hot End: Customizable All Metal Hot End!
CONGRATULATIONS! Seems like such a short time doesn't it - you should be proud!
I'd like both, but if I had to choose only 1.... I'd go for the .25 because I usually print smaller parts.
How about a bowden version of the heatsink as a stretch goal?
Have an upboat. I agree.
- RP Iron Man
Thanks for the input guys!
I'll definitely consider a bowden heat sink, though this is surprisingly troublesome to integrate with the customizability of the hot end. I have a few ideas, I'll try to figure something out.
As for the Prometheus STLs, here they are:
http://www.thingiverse.com/thing:302307
Eric
Eric
**Intuitive MULTI-FILAMENT 3D Printing** -- Successfully Funded on Kickstarter!
I designed the Prometheus V2 Customizable All-Metal Hot End. Buy online
Prometheus Hot End discussion thread
- Renha
Is that actual for all founders or only for new one? If first, may "DUAL Prometheus" perk have different nozzle sizes?RP Iron Man wrote: Let me know which optional nozzle size you guys would prefer in the comments!
Completely agreeccavanaugh wrote: How about a bowden version of the heatsink as a stretch goal?
3D printing is magic!
I'm totally on board with wanting a ready-to-go bowden version too!
- RP Iron Man
Hey Guys,
We are now well past the funding goal. Thanks so much to all of the supporters!
I have received a lot of input about possible stretch goals and I am currently weighing all of my options. Just so you guys know, I plan on offering BOTH 0.25mm and 0.6mm nozzles in the future, but I am just trying to get an idea of what people are more interested in.
I have also been asked about offering a bowden integrated heat sink. I realized that this is an important feature that many people would appreciate so I am working on a solution for this. I will likely offer an option of bowden or standard heat sink for all supporters before I start shipping. The bowden hot ends may ship a few weeks later than the standard hot ends. Anyway, I will be sure to let everyone know once I have all of the details sorted.
Let's keep this campaign going!
Happy printing
Eric
Happy printing
Eric
If you were able to offer add-on perks of different size nozzles, either separately or as a variety pack, I suspect you would get takers. I don't know that you have the volume yet to justify it, unless your manufacturer will change drills without additional setup fees.
- RP Iron Man
That's the thing, I need to be able to justify getting extra parts manufactured. It's not just the small drills, the length of the orifice is dependent on the orifice diameter so it would require reprogramming some parts.
As you mentioned, I just want to wait until I have the required demand before I jump ahead and start offering different sizes.
Eric
Eric
- Renha
McSlappy, what about double hot end version of mount? Will 2 Prometheuses fit in Rostock Max?
Hmmm... Interesting. I'll have a play and see...
- Renha
Great! And a question: could they be placed mostly above effector plate, or only below? At quick look?McSlappy wrote:Hmmm... Interesting. I'll have a play and see...
- RP Iron Man
Hey Everyone,
Thanks for all of the ongoing support. The campaign is now over 140% funded!
A few updates for you all. I have slowly been receiving more of the parts for the Prometheus Kits. The small cooling fans and metric hardware just arrived and there are other parts on the way!
I have also been sorting out the stretch goals. I really want to offer both the 0.6mm and 0.25mm nozzle sizes, but in order to do so I need to have enough demand. For now I think it is better to offer the 0.6mm nozzle size as the first stretch goal. I understand that many of you were more interested in the 0.25mm nozzle size. However, the 0.25mm nozzle will require more testing due to the higher extrusion force so I think it is a better idea to start with a more user friendly nozzle size. A 0.6mm nozzle size will also allow you guys to print with Taulman T-Glase!
I am setting the stretch goal for the 0.6mm nozzle at $8000. We are half way through the campaign with $4300 funded so I think this is doable. I understand that this stretch goal is still a bit high, but this is the funding that I would require to be able to offer the 0.6mm nozzle in this campaign. Even if we don't meet this stretch goal I will still be offering BOTH the 0.6mm nozzle and the 0.25mm nozzle sizes soon after the campaign, so don't worry! Meeting this stretch goal will simply allow me to offer these extra nozzle sizes sooner
Let's keep this campaign going so we can meet the stretch goal. Remember to spread the word as far as you can!
Happy printing!
Eric
Happy printing!
Eric
And you were worried after the first day of making the funding goal!
Told ya it would be fine!
- RP Iron Man
Yeah, we passed the funding goal sooner than I expected. Now I am just trying to keep things moving
Eric
Eric
- RP Iron Man
Hey Guys,
Thanks so much to everyone for the continued support. The campaign is now 180% funded!
Just a few updates. It looks like the Early bird perks are running out with just two Prometheus 1.75mm Early Bird perks remaining!
Many people were asking about bowden integration and I have been working on a solution for this. At this point, I need a bit of info from all of you about your bowden needs! I am asking that you please take a few moments to post your preference of "bowden" or "standard" hot end in the comments. For the bowden hot end you will need a specific pneumatic coupler that fits into the heat sink. I am using the same modified John Guest couplers that E3D uses so if you already have a few then you are good to go. Later on I will add these couplers as add-on perks that will ship with your hot end. I will need to know if you need just one coupler for the heat sink, or if you want to order a pair of them. I also need to know if you need PTFE bowden tubing with your order. I will add these as optional add-on perks later but I just want an idea of what everyone needs now.
TL/DR: You need to post a comment on the campaign page: indicate whether you ordered "1.75mm" version or "3mm" version and post "bowden" or "standard". If "bowden": post "one coupler", "two couplers", or any required number of couplers, etc... If you need bowden tubing: post "750mm bowden tubing", "1000mm bowden tubing", or any required length, etc...
Thanks everyone! Let's keep this campaign moving!
Happy printing
Eric
Happy printing
Eric
- RP Iron Man
Hey Everyone,
Thanks for all of your feedback and support. The campaign is now over 200% Funded!
I just wanted to let you guys know that I have finished sorting out the details for bowden integration. Since I do not have the quantity demand to make two different versions I decided to make all of the Prometheus Hot Ends bowden compatible. I made some minor changes to the heat sink design that allows Prometheus to be used in both standard and bowden configurations. I also managed to adjust a few other dimensions to eliminate mounting issues with some printers.
- Robo3d Users: Don't worry about printing a modified x-carriage if you own a Robo 3D printer! I adjusted the mounting dimensions so that Prometheus will be a drop in replacement for your old hot end.
- Bowden Users: If you want to use Prometheus in a bowden configuration then simply add your required bowden couplers/tube length to your contribution. I added extra perks for these add-ons so please visit the campaign page and select the perks that you require. Please do this as soon as you can as the campaign ends in 11 days!
- Shipping Date: Due to these design changes the shipping date will be a little later than initially expected. The revised Prometheus Hot Ends are now in production and should be complete by mid-June. I can realistically expect to start shipping by late June so you guys will start receiving your perks by early July. I apologize for this delay but I hope you guys can understand. I am trying to satisfy everyone's needs with these last minute mods!
*Remember to select your required bowden coupler/tubing add-on perks before the end of the campaign!
We only have 11 days left so let's keep this campaign moving!
Happy printing
Eric
Happy printing
Eric
- RP Iron Man
Hey Everyone,
Thanks so much to all who have supported this campaign!
Tomorrow is the last day of the campaign and I have now raised $7000. I am very thankful for the incredible support I have received from the community and I am really excited to bring Prometheus into existence!
I am confident that Prometheus will make many printers very happy and I can't wait to start shipping! The production is well under way and I will be sure to keep you all informed of the progress right up until delivery.
If you are interested in using Prometheus in a bowden configuration remember to select your required couplers and tubing add-on perks before the end of the campaign! There is only 1 day left so please add your couplers and tubing as soon as you can!
Once again, thanks so much to everyone for all of the support. This project was made possible by your contributions so you are all responsible for making Prometheus a reality!
Prometheus will be available for pre-order on my website after the campaign but you can contribute to this campaign now (If you haven't done so already) to take advantage of the free shipping!
I keep you all updated!
Happy printing
Eric
Happy printing
Eric
Thanks for the update Eric, I've added my bowden preferences to the campaign page and I'm extremely happy for you. Consider where you were 60 days ago... A lot changes in 2 months eh?
Congrats again!
Congrats again!
- RP Iron Man
Haha! Yeah, a lot happened in the last 2 months
It's all thanks to the support I received from all of you guys!
Thank you all.
Eric
Thank you all.
Eric
- RP Iron Man
Hey Everyone,
There are only a few hours left in the campaign!
If you are interested in using Prometheus in a bowden configuration please select your required couplers and tubing add-on perks before the end of the campaign!
Thanks,
Eric
Thanks,
Eric
How and where do we do this?
- RP Iron Man
Hey Gordon, I emailed you this message but I'll post it here as well in case you haven't seen my email.
I added extra add-on perks for bowden couplers and tubing so you can see them on the right hand side of the campaign page. You can select:
One coupler, Two couplers, and 750mm, 1000mm, 1250mm, or 1500mm tubing. Just contribute the add-on perks that you want and I will ship them with your DUAL Prometheus Hot Ends.
If this is too much trouble you can just look at the perk prices and make a single contribution equal to the total value of your required add-ons, and then just respond to my email indicating what you need.
Let me know if you are still unsure about anything.
Thanks so much!
Eric
Thanks so much!
Eric
Eric, just to be clear.
I got an early bird 1.75 kit and I indicated I needed a single coupler. Do I need to add the $3 to the order?
- RP Iron Man
Yeah, $3 would be for one of the couplers.
Sorry for the added inconvenience... I would have liked to make a standard one-size-fits-all bowden package instead of these add-ons but not everyone needs the same number of couplers or length of tubing. This was the most effective way I could do this with the Indiegogo platform. I don't like the "perk" aspect of the Indiegogo platform because there is no quick solution for product variations. Anyways, I have to put up with this for just a few more hours.
I hope this this is ok for you guys! If you have any trouble we can easily do this independent of Indiegogo. Just let me know.
Thanks,
Eric
Thanks,
Eric
