Page 27 of 39
Posted: Thu Jan 22, 2015 5:58 pm
by 3D-Print
Just placed my PEI print surface as detailed above: In summary, I followed the plan as detailed by "mhackney" (
http://forum.seemecnc.com/viewtopic.php ... &start=618). In summary......
1) Triple-washed the glass with dishwashing soap, then washed with Windex, then isopropyl alcohol. I placed it on a micro-cloth and let it dry
2) Then, I placed the 3M tape - TapeCase 468MP 12in X 12in as detailed by "nitewatchman" (
http://forum.seemecnc.com/viewtopic.php ... &start=621)
3) Then, I washed the PEI with Isopropyl EtoH, let it dry, then laid it down as described by "nitewatchman" (see above link)
4) With that, there was no bubbles!!!! I used the micro-cloth and did a rub down by hand.
Worked Awesome and is very adherent!!!!
Again thanks to everyone for all the great insight. Now to calibrate and print.
Dan
Posted: Thu Jan 22, 2015 6:40 pm
I purchased another sheet from Amazon today, it will arrive Saturday, so I can see first hand if there are any special cleaning requirements. Stay tuned.
Posted: Fri Jan 23, 2015 12:08 am
by dunginhawk
So im running PLA on my rostock tonight and not even wiping it down between prints and its sticking great.
SO im not sure why the other one isnt cutting the mustard, but i should replace it anyway.
Posted: Fri Jan 23, 2015 7:57 am
Very odd!
Posted: Fri Jan 23, 2015 4:21 pm
by Rando
626Pilot wrote:Rando wrote:For YOU maybe. Others on this forum, however, might be smart enough to consider the opinions and experiences of others when they are generously offered.
It's fair to say that it works fine with the clips' "arms" left intact. The clips themselves are more of a hazard than the arms because they will be the first thing a tool collides with. I never saw a reason to remove them myself. On these printers, they just aren't in any path the robot is likely to follow.
The full 27-page thread talks about a range and variety of printers, and it is over that range I addressed in my post. This thread is referenced in many places across the 3D community as a primary place where the history of PEI beds, getting them to stick and getting things to stick to it, can be seen in full. MANY 3D printers on the market are the kind where the y-axis moves the whole bed. For example, the TAZ4. On the front, back and left sides of the bed, a dangling arm on the underside can snag on the y-axis belt, the stepper motor pulley, the metal frame, and even sometimes the x-axis wiring. In such instances they represent such a clear and present danger I thought it bore mentioning. You know...the way people in forums do. Help each other out and sh!t like that.
But apparently many here believe the world is only populated with their beloved Orion delta-style machines, and all advice for others is dismissed. I guess I must have missed the big red sign proclaiming this a phase-III online community, where outside new opinions are denounced and castigated before discovering their truth; where a vocal few insist on making rude comments to knowledgeable people looking to contribute. In case you're wondering, phase-IV online communities exist when people stop contributing because this exact kind of push-back makes it not worth the time it takes to research, write, edit and post. That phase is called "imminent community failure". No worries, I'm not new to seeing this phenomenon play out. Just so you know, I tend to have backed up my posts with a full examination of the facts before posting, so no, your blanket statements in fact do not diminish the truth of my statements.
Okay, so here's few more reasons for those who won't care anyway: the arms are heatsinks. Having problems with the edge of the bed getting cold? Well guess what: those arms dissipate heat too and in a small way add to your problems. How about it just looks better with them off? I suspect the number and kind of reasons could just as well be endless, but a bunch here believe that nothing ever said will ever convince them to try anything that would ever challenge their long-ago made up minds. Fine...you have fun with that. It doesn't matter whether you believe me, within six months you'll know I'm right.
Do people really leave a #2 Phillips screwdriver in every screw they put in? How about a hex key in a socket-head screw? Do you leave the empty oil container under the hood of the car? Do you drive off with the gas-filler hose still in the side of the car? Wait...I'll bet you leave that plastic protective film on all your electronics, don't you? The idea that the installation tool is not to be left in place is not normally a foreign concept to technical people, so it's hilarious how much push back some people are giving. Sure...Heroin won't necessarily kill you every single time either...so go for it!
For that non-zero population to whom the advice applies and is important, well now they know. For the naysayers, just so you know, the existence of that population proves that your assertions that somehow the arms can always be left on is nothing more than a really obvious logical fallacy. Take 'em off, or don't, I don't care. I don't leave loose screws in my machinery, no matter how likely it might be to not be a problem. And when I see a preponderance of people making what could be a damaging mistake, I for one am willing to say so, unbowed by the protestations of those to whom the advice doesn't apply.
Silly silly people.
Posted: Fri Jan 23, 2015 4:42 pm
Thanks Rando. I had no idea my thread was read by so many. Having been hit in the head by a binding clip (on an H1 printer I built moons ago) your comment was understood by me. I leave them on my Rostock because I am constantly swapping beds - I have a number of plates with different surfaces (glossy PEI, matte PEI, PrintInZ, BuildTak, and several others). The bottom side of the bed surface on a Rostock is insulted. I have a 1/8" aluminum heat dissipator under the bed and the top of the clip is above the glass and surface, so heat radiation is not an issue (but it is something that I was concerned about way back when).
I welcome the non-delta crowd here, we all have "sticky" issues to deal with (pun intended) so maybe my passion for PEI will help others!
One last thing and then I request that this line is dropped, permanently. The two clips back by the electrical connector are red and the rest are zebra striped, they actually look kind of cool with the metal handle folded back.
cheers,
PEI recap sticky thread
Posted: Sat Jan 24, 2015 10:16 am
1/24/2015 UPDATE: If you are coming here for the first time, it can be a bit arduous to wade through the 27 pages of discussion here. I've summarized the final materials and process in a new sticky thread. If you just want to learn one tried and true way of installing and using PEI, go to that thread. There are many other comments, suggestions, installation techniques here if you choose to wade through!
Posted: Sat Jan 24, 2015 3:22 pm
Well, I installed a new sheet of the Amazon 0.03" PEI today with the matte side up. I photographed the process and updated the sticky install thread I created this morning. Once installed, I cleaned the surface with isopropanol, recalibrate Z and printed. Perfect stick first time. You can see the photos in the other thread.
I do have a new piece of the McMaster Carr 0.04" PEI to test too. I noticed that this sheet is glossy on both sides. I seem to recall helping a friend last year and his was matte on one side, but maybe I don't recall correctly. I'll install this sheet later this weekend and see how it goes.
BTW, the photos are of PLA at 185°C printing on the PEI at 50°C. Absolutely no problem, I did not have to restart or do any tomfoolery, it just stuck the landing and printed perfectly first time.
Posted: Mon Jan 26, 2015 6:23 am
by 626Pilot
Rando wrote:I have to be right all the time. Anyone who suggests an alternate to something I say is a "silly, silly" person. Please get ready for more shrill, abrasive posts anytime a person disagrees with me.
That's how you're coming off right now. You have been abrasive with two people in this thread already, and I'm asking you to stop. We like to keep it friendly and professional here. Insinuating that anyone who disagrees with you is retarded is neither friendly nor professional.
Posted: Mon Jan 26, 2015 12:32 pm
by bot
Yeah that reaction was kinda nuts.
Posted: Mon Jan 26, 2015 1:12 pm
by Nareikuk
I must have a load of slippery ABS. I am struggling to get it to stick to PEI very well. It sort of tries to stick, but not at all well. The PEI is the Amazon 0.03" stuff, stuck down with 3M tape. I've washed it, sanded it, cleaned it with acetone, cleaned it with surgical spirit. I have ordered some IPA, but have already tried IPA wipes with no luck. I disassembled and re-built the effector platform and re-calibrated a few times. Disappearing purple works quite well to stick parts to PEI and is the only way I can get stuff to stick, but that worked well on glass too. I've tried a few different tips from mhackneys thread to get a better first layer but it has not helped on 'raw' PEI. The pure IPA is about the last thing I can think of to try.
Any other ideas?
Posted: Mon Jan 26, 2015 2:38 pm
Odd Nareikuk. Are you using Canola oil perchance? What temp are you running your extruder and your bed at? Have you measured your first layer height? Is it on the target? If not, fix that.
Posted: Mon Jan 26, 2015 2:56 pm
by Nareikuk
Definitely not using oil of any sort. Bed at 85C, but I tried 80C up to 95C. Hot end is E3Dv6 at 230 currently but also tried range from 218 to 245. I measured 1st layer at 0.2mm with expected 1st layer set to 0.25 (up to 0.35 tried too). Also tried a range of 1st layer heights to try to get this working. I am printing really close to the centre of the bed, within 25mm to try to limit affects further out. I did try to print a disc 270mm diameter, and while the first layer looked OK, not great, but usable, the disc detached itself sometime later after about layer 4 or 5. I wasn't there, and the curled up disc was on the floor with plenty of plastic around my desk and floor too
One common thing about the prints detaching from the bed is that they all detach from the direction of the Y-Z axis - so quite likely a levelling/adjustment issue along with poor bed adhesion.
Smaller prints are fine if I use the glue stick on the PEI. I printed the snowflake vase with glue stick on the bed and it stayed stuck down nicely. Without the glue stick and it lifted early on in the print.
I'd really like to get away from the glue stick and people seem to be getting good results from raw PEI, so it must be possible.
Posted: Mon Jan 26, 2015 3:00 pm
by teoman
If you are not printing exotic materials, the whole benefit of PEI is that you do not need any adhesives or the other messy stuff.
Posted: Mon Jan 26, 2015 3:15 pm
by Nareikuk
Yep it sounds like good stuff. I am just printing ABS at present to get this dialed in. I know it can be made to work, just need to figure out what I need to do to make the PEI want to stick to ABS. I might still not have the mechanical adjustments right, but then I'd expect even the glue stick to fail. There might be some contaminant on the PEI that I've not managed to clean off yet which is what I suspect most. I'd have thought the 1500 grit sandpaper to take care of that along with an acetone wipe down. IPA will arrive tomorrow so maybe that will help...
Posted: Mon Jan 26, 2015 3:40 pm
You likely saw my post on Saturday. New piece of PEI from Amazon, simple cleaning with IPA and success on first print (PLA). I have printed ABS on it now. Yesterday we did a Kossel plate with the 0.4mm McMaster Carr for my son. He had to go back to school so we didn't have a chance to test it yet.
Posted: Mon Jan 26, 2015 3:49 pm
by Nareikuk
Yep,I read that in the middle of cursing my printer. Rubbed salt into the wound! The closest thing I could get to IPA was some IPA wipes, but they were only 70% IPA, no idea what the other 30% might be - probably some sort of disinfectant as I guess these are for pre-injection cleaning of the skin. I have 500ml of the stuff arriving tomorrow and will report back here if it works. I have the PEI all scrubbed down and glue removed ready for a polish with IPA.
BTW, I am trying to use the matt side of the plastic.
Posted: Mon Jan 26, 2015 3:51 pm
The wipes are what I usually use. The 30% is water. The IPA is the disinfectant. But, sure IPA dissolves grease much better. The matte side is actually easier to use!
Posted: Tue Jan 27, 2015 3:34 pm
by Nareikuk
Cleaned and also re-sanded and re-cleaned using 99.9% IPA. NO luck getting ABS or PLA to stick particularly well. Good news is that the first layer is now looking really good and measures accurately - i.e. 0.25mm 1st layer measures as 0.25mm. Just need to figure out how to make this PEI stuff stick. May as well be printing on teflon for all the stickiness it's showing. More like slightly tacky would be the best way to describe it. PLA even lifts at a corner when printing a 50mm square box with 2mm thick sides.
Posted: Tue Jan 27, 2015 4:08 pm
Then something is not right. PEI will stick tenaciously to both ABS and PLA. The open weave spools I sell can't be printed on anything else without significant failure, with PEI I get a 100% yield. You say .25mm first layer, what is your nozzle diameter?
[img]
http://cdn1.bigcommerce.com/server1200/ ... 80.jpg?c=2[/img]
Posted: Tue Jan 27, 2015 4:10 pm
by Nareikuk
I know this can be made to work, just don't know how. My nozzle diameter is 0.4mm.
Posted: Tue Jan 27, 2015 4:14 pm
Ok, try .2mm layer height. .25mm is a little large for a .4mm nozzle.
Posted: Tue Jan 27, 2015 4:17 pm
by Nareikuk
Will give that a go. Just to be clear, the first layer height is set to 0.25 with a normal layer height of 0.2. Will set the first layer to 0.2 and leave the other layers at 0.2 as well. I have the first layer width set to 0.3.
Posted: Tue Jan 27, 2015 5:02 pm
by Nareikuk
Ok, printed the first dozen or two layers after changing first layer height to 0.2.
Can't get the print off the print bed! How the hell did that happen? This was printing PLA because that happend to be what I last printed with when I got a lifted corner. All I did differently was to reduce the first layer height from 0.25mm to 0.2mm and I gave it yet another quick clean with IPA before printing. You may have completely solved the sticking problems with my PEI sheet
Thank you so much.
Print has just released while typing this - just as expected when the bed cools down a bit. First layer looks perfect - I might try increasing the extrusion multiplier up from 0.9 back towards 1 to see when blobbing on first layer starts again. I'll give ABS a go tomorrow evening too.
Posted: Tue Jan 27, 2015 6:05 pm
by teoman
Try increasing your temperature.
I print at 115 degrees (according to the LCD) and i have an aluminum heat spreader under the glass.
