Page 14 of 17
Re: Another rostock max build
Posted: Sat May 04, 2013 4:18 pm
by cambo3d
Flateric wrote:Where did you get you hands on those, hobby store? What's the blue one at the bottom?
that's my bling bling 5mm adjustment wrench :mrgreen:
im gonna gather up all the part numbers to the parts I used and post them up for you guys. along with the dxf file for the longer top support plates.
Brian from trick laser cut these top plates for me when I ordered my tl-1 frame. Maybe he wont mind doing some of these for you guys also.
Posted: Sat May 04, 2013 5:08 pm
Don't forget the part number for the wrench, that thing is COOL!
cambos T-buck tensioner parts list and files.
Posted: Sat May 04, 2013 6:00 pm
by cambo3d
Turn buckle tensioner parts, FOR modified top supports.
I purchased some of these items in bulk, the quantities needed for assembly are in parenthesis ( ).
• (1) Dubro - DUBQ2316 – 12 pack of monster ball links, package has hardware needed for installation so don’t lose the parts
• (3) Packages of Great planes – GPMQ3754- Turnbuckle/pushrod, these come two per package.
• (6) 2.5in 6-32 screws Mcmastercarr part# 91772A161
• (12) 6-32 washers or #6 washers
• (3) 5/16 OD x 1.5in length nylon spacers for #6 screws. Mcmastercarr part # 94639A371
• (1) 5mm adjustment wrench, towerhobbies.com carries an assortment of these, just pick one you like. http://www3.towerhobbies.com/cgi-bin/wt ... 5mm+wrench& search=Go
• (6) Modified top support plates dxf file below.
Notes:
All the turnbuckles will need to be cut down slightly, they are 54mm in length, I removed 4-6mm off each end to give me the adjustment range I needed. If you can find shorter length turnbuckles in the 6-32 size and around 42mm that would be a better fit for the current top support plates. You can also modify the dxf file so that there is more spacing in between the very top and the bottom hole, that way you don’t have to cut down the turnbuckles. My top support plates were already cut so I did the later.
If you need to cut down the 6-32 turn buckle, this can be accomplished with just some wire strippers that have 6-32 bolt cutters integrated, makes quick work of it. Just use a file to remove any burrs.
dxf files for modified top support plates.
top tensioner dxf file metric.dxf
(577.29 KiB) Downloaded 316 times
top tensioner dxf file standard.dxf
(330.94 KiB) Downloaded 359 times
Posted: Sat May 04, 2013 6:58 pm
by cambo3d
my all metal hotend arrived today also,
looks pretty, this is for 3mm filament so im waiting on some other things to test this out.
Posted: Sat May 04, 2013 9:20 pm
by Flateric
Nice! A trinity labs one, I grabbed one of them too. Shame about the 3mm only so far from them.
all aluminum platform for magnet ends
Posted: Wed May 08, 2013 3:57 pm
by cambo3d
excited to show this off today, made from 1/8" 6061 aluminum. http://forum.seemecnc.com/viewtopic.php ... 300#p10848
off the cnc router
weighs about 24g, don't know if this is good or bad, but seems fairly light to me.
comparing to stock
can use ball studs with magnets ends on the rods or, cup mount for ball bearing, etc.. still working out the design
Posted: Wed May 08, 2013 5:31 pm
cambo3d wrote:my all metal hotend arrived today also,
Mine arrived as well, the resistor supplied is too large to fit the hole in the heater block, so I won't be assembling it for a couple of weeks, by the time the heater cartridge I ordered arrives I'll be travelling for business. :/
Posted: Wed May 08, 2013 5:46 pm
by cambo3d
That's strange mine fits perfect. although i don't know if I'll use it or not. I want to switch to the cartridge style.
Posted: Wed May 08, 2013 6:23 pm
by foshon
cambo3d wrote:That's strange mine fits perfect. although i don't know if I'll use it or not, I believe its a 24v resistor. I want to switch to the cartridge style.
Be careful, if you put the thermistor in the nozzle it is damn near impossible to get PID right. I had to butcher my firmware to get close.
sneek peak at the under mount pg35l direct drive extruder mo
Posted: Wed May 08, 2013 6:44 pm
by cambo3d
here is the prototype mount for the pg35l extruder.
This version mounts the direct drive extruder underneath the rostock platform. vs the top as shown on this thingiverse link http://www.thingiverse.com/thing:43457
Re: sneek peak at the under mount pg35l direct drive extrude
Posted: Thu May 09, 2013 2:26 pm
by foshon
cambo3d wrote:here is the mount for the pg35l extruder.
Are you going to post that stl? Please? I used thing:39966 and I am not impressed. Your's looks like the ticket.
Posted: Thu May 09, 2013 2:42 pm
by cambo3d
Will do , once everything is everything is fit up properly.
Edit :Brad from ultibots posted this file Today. You can find it on thingiverse. http://www.thingiverse.com/thing:87028
its the same one i had him modify for me.
Posted: Thu May 09, 2013 5:32 pm
Cambo3D, how do you find the time for all the things you do? :?
Posted: Fri May 10, 2013 1:10 am
by cambo3d
I don't know really, when I start project, I don't stop till I'm satisfied with the results. Usually this means late nights and long days. When I have downtime waiting for parts to arrive, i'm still working on the computer drawing up ideas for other projects, checking designs getting ready for production run... I just fit in whatever I can do, when I can.
All aluminum platform for magnetic arms
Posted: Fri May 10, 2013 2:32 am
by cambo3d
Just trying to gauge how many people would be interested in this. I have a proto type made as you can see from recent post. http://forum.seemecnc.com/viewtopic.php ... 340#p11917
Originally made this for my own rostock but I've had a couple people interested in it also.
so I'm wondering many would be interested? What you guys think a reasonable price for this would be? If there's enough people interested, I may be able to swing it.
Posted: Fri May 10, 2013 2:42 am
by ApacheXMD
I'd totally be interested in a machined magnetic joint solution. Would you also have machined parts for the cheapskate side?
Personally, what I'd be willing to pay would depend on what was included, i.e. cheapskate ball mounts, mounting hardware, magnet cups, etc. Basically it would depend on how much work I'd have to do to get it up and running.
That machined effector looks great, btw.
Re: All aluminum platform for magnetic arms
Posted: Fri May 10, 2013 4:05 am
cambo3d wrote:Just trying to gauge how many people would be interested in this. I have a proto type made as you can see from recent post. http://forum.seemecnc.com/viewtopic.php ... 340#p11917
Put me down as interested. Price can only be determined by you because we have no way of knowing the cost of materials, time invested, and profit.
Posted: Fri May 10, 2013 2:29 pm
by cambo3d
[quote
Put me down as interested. Price can only be determined by you because we have no way of knowing the cost of materials, time invested, and profit.[/quote]
I know what my cost are, just wanting to see what people are willing to pay. I'm trying to work opposite here by starting off with what people are willing to pay then do what I can to get it within you guys price range.
apache, I have an idea for the carriage side, i'm still working on and testing.
Posted: Fri May 10, 2013 4:04 pm
by dbarrans
You milled this, right? Can you laser cut it instead? Would that save some cost?
I'd pay $20 for it. Maybe a bit more. Someone has to throw out a number to get started. If it was part of a kit that included a solution for the carriages, I'd pay more. How much more depends on how much I still need to do myself.
I've started collecting parts for something, but haven't yet worked out how I'll machine what I need. So far I have the magnets, some 1/2" balls, and some delrin rod. Probably going to use carbin fiber tubing from dragonplate.com.
- dan
Posted: Fri May 10, 2013 5:37 pm
A laser cutter capable of cutting .125" aluminum is veeeery expensive. I'm sure he'd be happy to cut you one if you supplied the laser though! :D
Posted: Fri May 10, 2013 5:50 pm
by cambo3d
I dont have a laser cutter Dan, but i'll see what I can do about milling these out at a lower cost but $20 wont even cover the cost of the tooling. Unless there are more people interested.
all aluminum magnet joint progress
Posted: Thu May 16, 2013 12:37 am
by cambo3d
some more progress on the all aluminum magnet joints compatible with seemecnc parts.
testing fit up
little more than a pound of weight
all aluminum hot end mount for xnarons conversion
Posted: Sun May 19, 2013 7:02 pm
by cambo3d
test fitting all aluminum hot end mount prototype . compatible with xnarons conversion.
Posted: Mon May 20, 2013 2:32 pm
by Schneider
Well, if you plan of selling a complete kit, i'm buying. I'm pretty sure i'll eventually be able to make mine work..i think!
Posted: Mon May 20, 2013 3:29 pm
Cambo3d, I am confused how your effector works. Xnaron's mount the balls at an approximate 30 degree angle,
yours appears to be flat. How has the testing gone on your aluminum version?
