Printing in a drafty room
Re: Printing in a drafty room
Yes, i usually run PLA at 60C, and ABS at 80C, whether I use glue stick or hairspray or PEI.
I use 55C for all my PLA work. I've never printed on cold glass.
davec3275
Post by davec3275 »
I usually have my bed heated to about 75 for PLA.
davec3275
Post by davec3275 »
Well, thought I would give a quick update. After lathering the build plate with glue and numerous attempts to calibrate the Z height, I had almost given up the ghost when it comes to printing. I have begun to receive my order of PEI and tape in order to upgrade the build plate as well as upgrade the hot end to an E3D V6.
But then I decided to give MatterControl a shot. Well, low and behold I am able to successfully print with the prints sticking to the bed quite nicely.
It is weird because I tried just about every setting I could think of in S3D. I do not know what is different but for now, I guess I will be using MatterControl.
KAS
Post by KAS »
davec3275 wrote:Well, thought I would give a quick update. After lathering the build plate with glue and numerous attempts to calibrate the Z height, I had almost given up the ghost when it comes to printing. I have begun to receive my order of PEI and tape in order to upgrade the build plate as well as upgrade the hot end to an E3D V6.
First Layer Hieght % on the layer tab? It's about the only thing that could cause a different fist layers between slicers. I set mine to 100% then calibrate with feeler gauges.
Also uncheck Update Machine Definition and Update Firmware Configuration on the G-Code tab.
