Page 2 of 2
Re: V2 in Minnesota - plenty of questions.
Posted: Thu Dec 11, 2014 3:31 pm
by JFettig
I will have to post it up when I get home :)
Posted: Thu Dec 11, 2014 5:16 pm
by JFettig
Here are the files
http://repables.com/r/436
Posted: Thu Dec 11, 2014 5:44 pm
by BenTheRighteous
Thanks! How do you attach that 3rd screw? Do you just thread it into the print itself or do you manage to get a nut in there somehow?
Posted: Thu Dec 11, 2014 5:53 pm
by JFettig
I threaded them all into the print using sheet metal screws
Posted: Thu Dec 11, 2014 6:23 pm
by RegB
Koooo_wel, THANKS !!!
Gotta print me one (or several) o' them (-:
Posted: Fri Dec 12, 2014 6:15 am
Thank you for posting the files, this look like a good fan mount!
Posted: Sun Dec 14, 2014 11:48 pm
by JFettig
Had some corners lift on kapton so I added abs juice... Wow that made it impossible to get the parts off. Mix juice thinner or skip kapton?
Posted: Sun Dec 14, 2014 11:51 pm
by jdurand
Windex (tm)
Posted: Mon Dec 15, 2014 12:05 am
by JFettig
Tried, didn't help with removal of the parts
Posted: Tue Dec 16, 2014 9:15 pm
by jram
I third that! I like that design, my shroud now only seems to cool 1/2 of the material.
Posted: Fri Dec 19, 2014 12:47 am
by lightninjay
Hey JFettig! I just wanted to say thanks for the files! Your mount works great :)
It's helping me print my cousin a Tardis at the moment!
Posted: Fri Dec 19, 2014 9:25 am
by JFettig
lightninjay wrote:Hey JFettig! I just wanted to say thanks for the files! Your mount works great :)
Awesome! glad they're getting put to use!
I'm building an enclosure for my printer, just 3 more prints for the top brackets then need to print up 3 or 4 parts for the latch setup. I'm running out of white ABS so the rest of the parts might have to be black.
[img]http://i.imgur.com/49ADE0K.jpg[/img]
Posted: Fri Dec 19, 2014 8:24 pm
by JFettig
Just printed the last one of the enclosure brackets, I had about a foot of white filament left at the end of that! Then I noticed that my PEEK fan wasn't running, somehow it jammed up or something, the fan shroud is completely melted but the hot end seems fine surprisingly!
Posted: Fri Dec 19, 2014 9:32 pm
by Mac The Knife
It seems that bushed fans don't last long in these printers. Both my Rambo and Peek fan have been replaced with ball bearinged versions.
Posted: Fri Dec 19, 2014 10:10 pm
by nitewatchman
Mine also, Peek Fan about a week - Rambo Fan about a month.
Posted: Fri Dec 19, 2014 10:32 pm
by bot
I never even installed my rambo fan, and my first peek fan was DOA (essentially) and my second one seems to be slowly dying, but I've got an e3d on the way and a ball bearing 25mm backup for the seemecnc hot end which will be a backup to the e3d.
Posted: Mon Dec 22, 2014 2:04 pm
by jram
Hi JFettig. Just wanted to say thanks for making this stl available. Printed one out this morning and the fit is superb, seems to be cooling much better than my my original configuration.
