... but how does the software know when the nozzle hits the bed? Can it sense the load on the steppers?geneb wrote:The software does the moves
New calibration procedure for Rostock MAX
Re: New calibration procedure for Rostock MAX
- joecnc2006
the only problem is if you have an area lower than your set Z0 the software will not move below that.
Joe
The process that MatterControl uses utilizes YOU as the sensor. It will jog the head and ask you about where it's at. Just go through the process, you'll see what I'm talking about. It doesn't make any firmware changes so there's no harm in experimenting with it.
joecnc2006: Repetier-Host (and likely MatterControl) will not normally allow a -Z, but trust me if you send a "G0 Z-0.05", the firmware will obey it. (much to the displeasure of your build plate and nozzle...)
THIS WORKS !!!!! whoot thank you
Repetier firmware Version 1.0.1 configured for RAMBo SeeMeCNC Rostock Max with Z-Probing and Bed Leveling
https://github.com/xform3/Repetier-Firmware
Cool ... but with the Artemis this is a thing of the PAST!
well ... no for my V1, V2 and V3s LOL thanks then
