Re: How to adapt the ATX PSU for Rostock MAX
Posted: Mon Mar 31, 2014 10:13 am
I try to avoid the painfully obvious.
Have a look around and join today!
https://forum.seemecnc.com/
whooops... missed that one... thanks...geneb wrote:Remove the four nylon screws from the power supply and push it back a bit. It will drop out of the hole in the bottom plate...like it was designed to.
There was one message from a user who said you had to remove the bottom plate to get it out so what is obvious to you (because of your experience)geneb wrote:I try to avoid the painfully obvious.
That does sound rather obvious. If they can't figure that out they probably shouldn't be building kit printers. Thanks, Gene or should we call you Conan?geneb wrote:Eagle, the power supply hovers over a HUGE hole. It's supported in the front by the four nylon mounting screws and in the back by resting on the edge of the hole. If you take out the screws, the thing will likely drop on to the table with a rather noticeable *THUD*.
You would have to have it in five different languages.geneb wrote:YARGH!
You know, I bet I could make a killing if I made a set of Philips screwdrivers with "Pointy End Towards Screw" engraved on the shank.
Plus one line using symbols, for universal appeal, like on coffee cups.Eaglezsoar wrote:You would have to have it in five different languages.geneb wrote:YARGH!
