Re: I think I found the cure to Warping.
Posted: Mon Apr 08, 2013 11:51 pm
Excuse my ignorance, but what is garolite? IS that the grippy black tape you put on steps to not slip.
Or am I way off, LOL.
Have a look around and join today!
https://forum.seemecnc.com/
I don't think you have a choice, there isn't anything with close to the material properties of Nylon except Nylon that's printable.Polygonhell wrote:What material would you recommend I use in my case? I need something that is close to Poly, tough and flexible, with out the warp.
Some kind of synthetic board that Nylon 618 adheres really well to. You can get 12" X 12" board from Mcnaster Karr.Flateric wrote:Excuse my ignorance, but what is garolite? IS that the grippy black tape you put on steps to not slip.
elqisqeyano wrote:Some kind of synthetic board that Nylon 618 adheres really well to. You can get 12" X 12" board from Mcnaster Karr.Flateric wrote:Excuse my ignorance, but what is garolite? IS that the grippy black tape you put on steps to not slip.
They aren't something you download, but something you add to the model in a CAD or modeling package.elqisqeyano wrote: Where can I download those Mickey Mouse ears? My Garolite is in the mail. If I sent you a file could you put the ears on it for me? Or is it a simple process? I'm very new to this, but learning much as I go. Thanks in advance.
What about the problem with my hot end not reaching the good melt bonding temp that 618 prefers? With this problem I can't bother till I can get true 245 to 250 C. Where can I get one of those hot ends able to handle this kind of heat. 618 prefers 245 to 250 C to bond really well. If not at that temp, it starts to warp it's own layers and they strip right off.Polygonhell wrote:They aren't something you download, but something you add to the model in a CAD or modeling package.elqisqeyano wrote: Where can I download those Mickey Mouse ears? My Garolite is in the mail. If I sent you a file could you put the ears on it for me? Or is it a simple process? I'm very new to this, but learning much as I go. Thanks in advance.
It's simple enough you take the model and where it sits on the bed you add circles centered on the outside corners, and make them ~1 layer high.
The idea being that round shapes are less prone to warping because the shrinkage acts more evenly than at sharp corners and you have a lot more surface area in the areas prone to warping.
Like File2Part and Inventor Fusion 2013?Polygonhell wrote:They aren't something you download, but something you add to the model in a CAD or modeling package.elqisqeyano wrote: Where can I download those Mickey Mouse ears? My Garolite is in the mail. If I sent you a file could you put the ears on it for me? Or is it a simple process? I'm very new to this, but learning much as I go. Thanks in advance.
I'm just not very good at this CAD stuff, no experience in it. I guess I can try and solve it on my own by practice. Which CAD program would you recommend? I use inventor fusion 2013Polygonhell wrote:They aren't something you download, but something you add to the model in a CAD or modeling package.elqisqeyano wrote: Where can I download those Mickey Mouse ears? My Garolite is in the mail. If I sent you a file could you put the ears on it for me? Or is it a simple process? I'm very new to this, but learning much as I go. Thanks in advance.
USMCPelto wrote:Anyone have any tips on smoothing the surface of an object? The bottom (on a thin nylon sheet) is absolutely smooth, but the outside of my object where the Nylon layers meet obviously is a little bumpy. Is a fine grit sand paper the best solution? Or some sort of quick chemical bath?
Fyi, I'm using a 1/16th inch thick sheet of a smooth Nylon, it's working quite well. I didn't get any luck with Blue tape.
Pain in the butt ain't it? It's like rubber and strong as heck.USMCPelto wrote:Amazon. I got 2 sheets for about 8-10 dollars a piece, and used second day shipping (needed it for a business).
http://www.amazon.com/gp/product/B000MA ... UTF8&psc=1
Or this, they're pretty much the same.
http://www.amazon.com/gp/product/B0070Z ... UTF8&psc=1
They look identical, so I really can't tell which one I'm using. I'm pretty sure they're the same thing. I cut it into a rough circle, clip the hell out of it to my heated Onyx, and bam. I have an issue with the very middle of it slightly popping up...more clips sort of helped, but it's still popping up ever so little. Doesn't affect my prints too much, as I'm printing small, centered objects.
Again though, does anyone have a tip to smooth a 618 Nylon print out?
Here is the link to that ABS plus material. Same material used on the Stratasys Machines.USMCPelto wrote:Amazon. I got 2 sheets for about 8-10 dollars a piece, and used second day shipping (needed it for a business).
