Page 2 of 4
Re: Rostock V3 Bed issue
Posted: Fri Oct 07, 2016 2:41 pm
Also, on my V3 I found that if I decreased the probing radius a bit I get much nicer calibration. I observed several early probes (with the original probe diameter) that the effector actually tilted a bit near my X tower. The results were basically the same as what I see for your Z tower. You can use David Crocker's bed file generator to generate the points automatically:
http://escher3d.com/pages/wizards/wizardbed.php
Set number of peripheral points and halfway points to 3 and pick the probing radius you want. I used 135mm:
-116.910 Z-probe X1
-67.500 Z-probe Y1
116.910 Z-probe X2
-67.500 Z-probe Y2
0.000 Z-probe X3
135.000 Z-probe Y3
Posted: Fri Oct 07, 2016 3:11 pm
by javiercordero20
mhackney wrote:Also, on my V3 I found that if I decreased the probing radius a bit I get much nicer calibration. I observed several early probes (with the original probe diameter) that the effector actually tilted a bit near my X tower. The results were basically the same as what I see for your Z tower. You can use David Crocker's bed file generator to generate the points automatically:
Set number of peripheral pants and halfway points to 3 and pick the probing radius you want. I used 135mm:
-116.910 Z-probe X1
-67.500 Z-probe Y1
116.910 Z-probe X2
-67.500 Z-probe Y2
0.000 Z-probe X3
135.000 Z-probe Y3
Any other settings I should check besides those?
Could you also explain how I should use the generated G-code? should I just run it the same way I used the probing.Gcode provided by SeeMeCnC?
- Capture.PNG (13.53 KiB) Viewed 18599 times
Posted: Fri Oct 07, 2016 3:42 pm
You DON'T use the generated gcode, you use the X Y positions in it. "You can use David Crocker's bed file generator to generate the points automatically". I pulled out the points I use in my post so you can just use those.
Posted: Sun Oct 09, 2016 5:54 pm
by ComJak
What exactly do you do with the points that are pulled from the bedfile generator?
Posted: Wed Oct 12, 2016 11:55 am
by Th0mpy
Hey everyone!
So, I don't have a V3 but I did upgrade my V2 with the new HE280 hot-end. So far I'm not getting anywhere near the quality I had been with the old setup. I have a few issues, but most seem correctable. The biggest issue I've seen so far, is with the automatic calibration. After running the automatic calibration I can see clearly that the end-stop offsets are being populated to a seemingly correct value, as well as the radius. If I then attempt to print a circular pattern the area opposite the Y tower is much lower than the rest. The other towers and corresponding opposite hypotenuse (i guess you could call it) all seem to be within an acceptable range.
So far, I've attempted to rule out mechanical issues. The towers are square to the plate. The belts are all tensioned properly and evenly. I've even ruled out the bowden tube and cable coming from above as binding on the arms. Also, the endstop switches are firmly mounted and solid.
I am calibrating cold. If I do not calibrate cold the hotend will crash into the plate OR will fail to complete the calibration and stop after it's probed the first tower.
Terribly frustrating, anyone have any good ideas? Is there something more which needs configuration to allow to calibrate while heated up? Could this be happening because I am not calibrating while heated?
Posted: Wed Oct 12, 2016 12:06 pm
Do not calibrate while heating with the accelerometer probe. You already observed the results!
Is the bed level issue (sloped along the Z tower) consistent? One gent here had a belt looped over one of the braces and it caused a similar problem. A loose endstop (you checked) as well as a loose carriage trigger screw or even a loose pulley on the Y stepper or loose stepper could all be suspects.
Posted: Wed Oct 12, 2016 12:08 pm
Oh, and watch the effector carefully when it probes out by the tower. I've actually seen mine rotate significantly, which is why I decreased the probing radius a bit.
Posted: Wed Oct 12, 2016 12:17 pm
by javiercordero20
ComJak wrote:What exactly do you do with the points that are pulled from the bedfile generator?
Mr. Hackney could you please explain what we need to do with the points generated?
Posted: Wed Oct 12, 2016 1:28 pm
by Xenocrates
javiercordero20 wrote:ComJak wrote:What exactly do you do with the points that are pulled from the bedfile generator?
What you do is you would edit the file that describes the bed probing points (bed.g on the duet). These points are inserted as different probe positions, and the rest of the bed.g file is assembled around them. As an example, I took the points, and have M561, G31 X0 y0, and G28 before the points, and then sometimes after the points a probe retract or similar would be needed.
Posted: Wed Oct 12, 2016 1:37 pm
by javiercordero20
Xenocrates wrote:javiercordero20 wrote:ComJak wrote:What exactly do you do with the points that are pulled from the bedfile generator?
Hello,
Alright cool. What file would that be for us using the provided Rambo Board?
Posted: Wed Oct 12, 2016 1:59 pm
You can edit them in the eeprom.
Posted: Wed Oct 12, 2016 2:17 pm
by Th0mpy
mhackney wrote:Do not calibrate while heating with the accelerometer probe. You already observed the results!
The slope seems consistent. What's weird is that when I had the old hotend I was getting really good prints, I didn't seem to have this issue after I manually calibrated the end-stop screws. After HOURS of manual calibration I even put a little locktite on the endstop adjustment screws to prevent them from wandering after it was set. Literally nothing else has changed except the firmware and hotend. So I don't think it's a pulley/loose stepper, but I will confirm tonight.
mhackney wrote:Oh, and watch the effector carefully when it probes out by the tower. I've actually seen mine rotate significantly, which is why I decreased the probing radius a bit.
What would be the cause for this? I might have noticed that but, again, i'll have to check when I get home. Which specific setting would adjust the radius; or is that simply the z-probing coordinates?
One final thing I forgot. After many hours last night, and a few beers, I decided to adjust the endstop screw out a ways. I did not runt the calibration after that and printed. It got better, not 100% exact, but I suspect that if I were to run the calibration again it would go back to the same thing. It does seem to point to a mechanical issue or a misconfiguration somewhere I just can't find it.
Posted: Wed Oct 12, 2016 2:42 pm
The accelerometer probe contacts the bed with a lot of force. It was startling the first time I watched it! In my case, it looks like the ball cup joint separates a bit and this is worse when the arm is near vertical like it is with the default stock probing points. Bring them in a bit, the arm has a bit of angle and the ball does not pop out of the joint as frequently (I've had it happen once though).
Keep working on it, something will show up and you'll have that Aha moment!
Posted: Wed Oct 12, 2016 2:52 pm
by Th0mpy
mhackney wrote:The accelerometer probe contacts the bed with a lot of force. It was startling the first time I watched it! In my case, it looks like the ball cup joint separates a bit and this is worse when the arm is near vertical like it is with the default stock probing points. Bring them in a bit, the arm has a bit of angle and the ball does not pop out of the joint as frequently (I've had it happen once though).
That is interesting!! I will have a look at that and report back.
I suppose I should get to work now, company time on a company computer, thanks for the feedback!
Posted: Wed Oct 12, 2016 2:59 pm
This is what the eeprom settings look like in OctoPrint (if you install the plugin). You can also see/edit them in Repetier and MatterControl.
Posted: Wed Oct 12, 2016 9:49 pm
by Th0mpy
Th0mpy wrote:mhackney wrote:The accelerometer probe contacts the bed with a lot of force. It was startling the first time I watched it! In my case, it looks like the ball cup joint separates a bit and this is worse when the arm is near vertical like it is with the default stock probing points. Bring them in a bit, the arm has a bit of angle and the ball does not pop out of the joint as frequently (I've had it happen once though).
Alright, I spent the better part of 4 hours banging away. I was able to fix one of my issues. I found out that the bowden tube did not get inserted all the way into the hotend. I had to make a small modification to the top nut, there was a bit of a burr which I had to trim in order to allow the tube to get inserted all the way. Anyway, you live and learn.
So, I pulled the probing points in a little bit. It didn't seem to make a difference. I checked and re-checked the pulleys, belts, and endstops. Any other suggestions? I am clean out of ideas.
Posted: Thu Oct 13, 2016 3:51 am
by DeltaCon
No suggestions to your problem, but just a small tip.
Th0mpy wrote:there was a bit of a burr which I had to trim in order to allow the tube to get inserted all the way.
I always use a pencil sharpener to "unsharp" the edges of the bowden tube a bit. That makes inserting it all the way a lot easier.
Posted: Thu Oct 13, 2016 8:57 am
+1 on DeltaCon's tip. I do the same or trim with a sharp hobby knife.
Posted: Thu Oct 13, 2016 8:58 am
Th0mpy, can you run calibration 3 times and after each, record the values saved to EEPROM so we can check for variability in the calibration process.
Posted: Thu Oct 13, 2016 9:12 am
by Th0mpy
So I was thinking of what could be the issue last night as I fell asleep. Is it possible that the radius of the Y arm is a bit shorter than the others? If that's the case could I set the delta radius correction for that tower?
Posted: Thu Oct 13, 2016 9:16 am
Possible but unlikely. I'd like to see if you are getting reasonable run-to-run reproducibility with the current setup.
Posted: Thu Oct 13, 2016 9:17 am
by Th0mpy
mhackney wrote:Th0mpy, can you run calibration 3 times and after each, record the values saved to EEPROM so we can check for variability in the calibration process.
Are you saying the endstop offset?
One thing I did last night which I thought was interesting... I used my iphone and did a slow-mo video of the hotend probing the glass, to see if there was any shifting of the platform. I ran the test about 4 times and while I was not specifically looking for changes in the offset it didn't seem to move about. I will do a better test tonight and focus on those measurements and report back.
Posted: Thu Oct 13, 2016 9:34 am
I'd like to see the results of all the calibration parameters:
x,y,z tower offsets
delta radius
z height
Posted: Thu Oct 13, 2016 7:35 pm
by Th0mpy
mhackney wrote:I'd like to see the results of all the calibration parameters:
x,y,z tower offsets
delta radius
z height
Ok, here's what I got. What do you think?
Test1:
- X offset - 5
Y offset - 3
Z offset - 0
Radius - 143.423
Height - 369.7
Test2:
- X offset - 6
Y offset - 4
Z offset - 0
Radius - 143.423
Height - 369.7
Test3
- X offset - 6
Y offset - 3
Z offset - 0
Radius - 143.437
Height - 369.712
Posted: Thu Oct 13, 2016 7:53 pm
Those are very consistent, which is good. Interestingly, I'm seeing a pattern with several of us having very similar "level" issues. I also ran Z height calibration a number of times in a row and it was dead on each time.
I am experiencing exactly the same thing you are also along the Y tower direction. I want to do this test: auto calibrate and test print to verify the tilt and then manually calibrate and compare the results.
