Page 2 of 2
Re: Color mixing ideas
Posted: Thu Sep 01, 2016 9:11 pm
by bot
My idea would be a mixing nozzle like this:
http://www.3m.com/3M/en_US/company-us/a ... 7497&rt=r3
Basically, the pressure of the material being pushed through the device is what turns the mixing screw. Scaled down, it could possible work?
Posted: Fri Sep 02, 2016 1:43 pm
by DeltaCon
Yes, I have worked with those mixing nozzles before. It needs quite a bit of pressure, and that would have to come from the extruder. That will have to be a super-extruder...
Posted: Fri Sep 02, 2016 2:50 pm
by bot
DeltaCon wrote:Yes, I have worked with those mixing nozzles before. It needs quite a bit of pressure, and that would have to come from the extruder. That will have to be a super-extruder...
Ah, that''s what I thought! Too bad. I had never even seen one in real life before. I imagine one could be designed that would mix way less cohesively, but still mix a bit, and work with the pressure available with a geared nema 17.
Posted: Sun Jul 23, 2017 1:19 am
by tylurker
Check out Arcus3d if you havent already. He uses a CMYK type system and a brushless motor powered mixing impeller. Pretty impressive.
