Page 10 of 19
Posted: Fri Jun 21, 2013 8:05 pm
by Generic Default
Thanks for finding the original magnets! Here is the amazon link for similar ones;
http://www.amazon.com/Disc-Package-Eart ... 08&sr=1-91
The problem with those is that they come in a pack of 10, so I'd have to buy 2 sets for the magnetic arm upgrade. 2 sets would make the shipping free though, so the cost would probably be about the same as from the other website after shipping.
Does anybody here have a big enough budget to experiment with different sizes of magnets? There are some bulk magnet packs on amazon that have like 200 magnets per set, which might be an alternative for people who want to customize their delta printers. I also saw a pack of 50 ceramic magnets at Hobby Lobby a few days ago that only cost $7. If something like that works for the Rostock, we could save a lot of money and shipping time.
Posted: Fri Jun 21, 2013 9:39 pm
by lordbinky
The ones you linked are N45, so they should be weaker than the N52. How that listing got 13lbs of hold while keeping a 1,000 less gauss is beyond me. Either they're over calculating or Revolution machines is selling themselves short.
Here's another site you can order magnets from, any amount of exactly of the same type Xnaron listed but they are still $3 more for 12 than Xnaron's pick before S&H.
http://www.kjmagnetics.com/proddetail.asp?prod=D66-N52
On the note of swallowing magnets, I don't know what triggered it to get so much attention recently. I had like 3 recall notices for various sets of bucky balls (tiny Neodymium magnets as a desk toy) I ordered. Everything with neodymium magnets has always had a warning and I know I've read a couple times where they explain WHY it's so dangerous when swallowed.
Posted: Fri Jun 21, 2013 10:18 pm
by Broose
Thanks for this link. Its pretty easy to chip these magnets and a source for just one or two is helpful
Posted: Fri Jun 21, 2013 10:30 pm
by doctorgonzo
You know, I know it's my first post and all...but you can stack smaller magnets and achieve the same results as a single larger one. Just saying.
Posted: Sat Jun 22, 2013 3:57 am
by Generic Default
Have you tested it before? I was considering getting a larger pack (100 or 200) of the thinner disk magnets and stacking them up, maybe like 5 per ball socket or something. I don't know how that would affect the strength though.
We should also consider magnets rated for higher temperature and maybe just bigger magnets in general.
http://www.amazon.com/CMS-Magnetics%C2% ... ium+magnet
Those are rated for 28 lbs, which might allow us to use higher accelerations. We should also try to find neodymium balls instead of using chrome steel balls. I just ordered the ones from Revolution machines, so I'll try to do this upgrade and make my own customized effector next week when I get my rambo back.
Posted: Sat Jun 22, 2013 6:52 am
by barnett
I think Jetpad is stacking thinner magnets.
Posted: Sat Jun 22, 2013 5:27 pm
by lordbinky
Stacking magnets won't get you quite as good of strength as a solid one, but for this it could be unnoticeable. I still ran into the problem of the magnets not being sold in the right amount, so they would come in packs of 20, when I needed 24 to be equivalent.
Posted: Mon Jun 24, 2013 9:45 pm
by Broose
One of the things I like most about the magnetic arms is the speed with which you can disasemble the platform with the hotend. I printed up a second platform and have the E3d set up for ABS and nylon, and the other head (makergear style, from the guy that makes the screw-in thermistor) for PLA. With the Dean's plugs, I can swap them out in hardly more time than it takes to swap the filament, then just change the Z-max length and PID and I'm back in business. With micro Dean's, it would be even faster.
Posted: Tue Jun 25, 2013 12:50 am
by ApacheXMD
With 4 pin micro deans, I have one connector for the heating resistor and thermistor, and then one additional connector for the PEEK fan and two pins for future expansion (lights probably).
Posted: Tue Jun 25, 2013 4:04 am
by kbob
Broose wrote:I can swap them out in hardly more time than it takes to swap the filament, then just change the Z-max length and PID and I'm back in business.
With some careful shimming, you might be able to keep the same Z axis length with both heads.
Posted: Tue Jun 25, 2013 7:44 am
Broose wrote:One of the things I like most about the magnetic arms is the speed with which you can disasemble the platform with the hotend. I printed up a second platform and have the E3d set up for ABS and nylon, and the other head (makergear style, from the guy that makes the screw-in thermistor) for PLA. With the Dean's plugs, I can swap them out in hardly more time than it takes to swap the filament, then just change the Z-max length and PID and I'm back in business. With micro Dean's, it would be even faster.
Very nice picture!
Are those the original Xnaron effectors, they look different somehow.
Posted: Tue Jun 25, 2013 8:19 am
by barnett
Those effectors look familiar to me... actually nicer than the one I printed.
I have to agree my favorite thing about the magarms is how easy it is to take off them off.
Posted: Tue Jun 25, 2013 8:26 am
by Broose
Eaglezsoar wrote:Very nice picture!
Props to Barnett for the effectors and Xnaron for everything else
http://forum.seemecnc.com/viewtopic.php ... rms#p13340
Posted: Tue Jun 25, 2013 8:59 am
http://forum.seemecnc.com/viewtopic.php ... rms#p13340[/quote]
Which slicer did you use to print the effectors? They look great! Are they ABS?
Posted: Tue Jun 25, 2013 11:35 am
by Broose
Eaglezsoar wrote:Which slicer did you use to print the effectors? They look great! Are they ABS?
I used Kisslicer and they are ABS. Of course, having the Xnaron mag arms helped with the print quality.
Posted: Tue Jun 25, 2013 12:09 pm
I noticed that the hotend you are using for the PLA has no slots in the Peek to aid in cooling, is that a problem for you?
I just went to his website and it does show there are no slots.
Is that a custom fan mount you have on the PLA head?
Posted: Tue Jun 25, 2013 1:18 pm
by Broose
Eaglezsoar wrote:I noticed that the hotend you are using for the PLA has no slots in the Peek to aid in cooling, is that a problem for you?
It seems to work fine for PLA with the fan. Yes, I made a little box to hold a 25mm fan next to the Peek.
FANHOLD.stl
(87.35 KiB) Downloaded 504 times
Posted: Tue Jun 25, 2013 1:46 pm
by Broose
ApacheXMD wrote:With 4 pin micro deans, I have one connector for the heating resistor and thermistor, and then one additional connector for the PEEK fan and two pins for future expansion (lights probably).
I think I'm going to go that way too and use the second micro deans for PEEK fan and work area fan(s). With Polygon's Repetier Firmware, he has separate outputs for the PEEK fan and work area fan(s). The PEEK fan comes on as soon as the hotend goes on, and the work area fans are controlled by G-code. Does anybody know if SeemeCNC's Repetier Max firmware works the same way?
Posted: Tue Jul 09, 2013 7:52 pm
by thenewguy
Thanks for the files xnaron!
I'm having a lot of trouble with printing the ends. I got the balls from the source you suggested as well as the magnets a few months back.
I purchased a carbon fiber rod from a link posited on here and it is the correct size however I printed this thing about 20 different times with different settings and can not get the balls to fit perfectly along with the arms.
Either the arms will fit and the balls will have to much play in the socket or vise versa. I even tried drilling out the ends some and still having trouble.
I'm using kiss and have it tuned pretty well. Am I missing anything that I didn't think of? Do anyone remember what they used for settings?
Off hand I know I was close with using
Vase
Jitter at 360
Wipe and destring on
Nozzle and infill at .55
Loops at 10
Layers at .2
Any help would be awesome thanks...
Posted: Tue Jul 09, 2013 8:39 pm
by Broose
What is the diameter of the carbon fiber rods? I bought enough for 2 sets from 2 different sources. one is .366 inch dia and the other is .376 inch dia. I couldn't get the larger diameter ones to fit and I ended up using the smaller diameter ones. Did the magnets fit all the way to the bottom OK? If so, you can chase the holes with a slightly larger drill bit most of the way down to fit your rods
Posted: Tue Jul 09, 2013 9:38 pm
by thenewguy
I checked quickly before I left for work and the rod was around .372- .374. The balls and magnets were about the same size as well. I used a bit but it didn't do much it was just shy of letting the rod set in place. I guess that's going to be my option in the end.
I figured it was a setting on kiss. That's why I'm asking. I tired increasing and decreasing abs in the extruder and that didn't help too much either.
Posted: Tue Jul 09, 2013 10:48 pm
by Broose
thenewguy wrote: I figured it was a setting on kiss. That's why I'm asking. I tired increasing and decreasing abs in the extruder and that didn't help too much either.
I assumed from your previous post that you tried scaling it up in Kisslicer to fit the rods and then the balls didn't fit correctly in the sockets (too loose). If so, I don't know of any other way to increase the size of the hole with a kiss setting that doesn't also increasing the size of the socket, hence the suggestion of the drilling option.
Posted: Wed Jul 10, 2013 7:09 am
by barnett
thenewguy wrote:Either the arms will fit and the balls will have to much play in the socket or vise versa.
I had this same problem. My 8 yr old saw me filing away at it and suggested the solution: make your own. The one I used (stl & scad) is attached. If something is not fitting for you, just tweak the parameters in the scad.
arm_end.stl
(310.93 KiB) Downloaded 632 times
arm_end.scad
(733 Bytes) Downloaded 622 times
Posted: Sat Jul 13, 2013 1:23 pm
Xnaron: I have the geared motor you used on your Bowden extruder and will be printing the printable parts soon.
Could you give me the steps per mm you use with your Bowden extruder so that I may be in the ballpark when calibrating?
Thanks in advance!
Posted: Sat Jul 13, 2013 8:48 pm
by thenewguy
Eaglezsoar wrote:Xnaron: I have the geared motor you used on your Bowden extruder and will be printing the printable parts soon.
Thanks in advance!
I am in the same boat. Have the motor on the way and the gear in the link. I'm looking for a write up though on any other parts used like what size screws ect.
Also I found a trick with the sockets for the balls. If you have a little play in them I take an extra ball heat it up over the stove. Once it gets pretty hot I place it in the socket for a sec or two until I see a very small amount of abs melt at the edge of the ball and quickly place under cold water. Just melting out any imprefections. Balls are now very tight in socket with zero play. Hopefully it don't throw off any measurements.
