Page 8 of 17
Re: Another rostock max build
Posted: Tue Mar 26, 2013 6:25 pm
by cambo3d
mhackney wrote:At this point:
getting good first layer adhesion - check
getting good layer adhesion without gaps or overfill - check with a little work to do on the blobs. Your extruder appears to be reasonably well calibrated and filament pressure correct.
no signs of backlash (i.e. parallel sides, plumb sides, layers stacked properly) - check
Now you can measure wall thickness, width and height and compare to your model and slicer settings - priceless (sorry, had to add that!)
do i really need to check that last line, or was that just being funny? seriously i dont know...lol
Posted: Tue Mar 26, 2013 6:30 pm
by foshon
cambo3d wrote:with the thin walled calibration print, what exactly am i checking for? height, width,??? http://www.thingiverse.com/thing:5573
or just thickness of the wall?
I have used that to help calibrate x-y steps/mm by comparing the width and length to what it was supposed to be. Most often though the goal with that cube is to tweak single wall thickness. Try to get a good measurement of the wall thickness, one layer is best (be careful not to cut into it with calipers). Now compare that to what the g-code thought the layer thickness was. If they are close, tweak your extruder flow modifier in the slicer. If they are way off apply the change to your e-steps/mm.
http://reprap.org/wiki/Triffid_Hunter%2 ... tion_Guide
Shoot down to "Slic3r/Skeinforge/Sfact settings".
Hope it helps.
Posted: Tue Mar 26, 2013 6:36 pm
Sorry, I was being serious and funny all at once! It is good to verify dimensions at this point.
Posted: Tue Mar 26, 2013 6:58 pm
by cambo3d
Hope it helps.
can't get that link to work..edit: finally popped up
Posted: Tue Mar 26, 2013 7:17 pm
by cambo3d
i'm noticing my extruder is getting loud, sounds like wood creaking ...hmmm
Posted: Tue Mar 26, 2013 7:53 pm
Egads foshon, that avatar scared the he!! out of me!
Posted: Tue Mar 26, 2013 8:01 pm
by Av8r RC
Mine also creaks. And sounds like a can full of rocks on retracts. My other printer has a direct drive extruder (bowden also) and is much, much quieter. I want to figure out how to get one on here and try it out.
Posted: Tue Mar 26, 2013 8:03 pm
by cambo3d
I tried to post a youtube video but its scrambling the video for some reason.. grrr.
Posted: Tue Mar 26, 2013 8:06 pm
Mine has the same squeak. I haven't gotten a chance to try 3in1 Oil on the gears yet.
Posted: Wed Mar 27, 2013 1:03 am
by cambo3d
I took the extruder apart and checked it nothing seems to be out of the ordinary, but at the same time while it was off, i sanded a bevel into the smaller gears near the filament roller, it seemed like it was rubbing against the bottom of the bowden adapter nut. I Put it all back together and the creaking noises went away. I can't be positive that's what caused it but might have been a combination of that and retorquing the assembly bolts. at least the noise is gone for now.
Posted: Wed Mar 27, 2013 2:41 am
by ApacheXMD
gabrielk had that issue too and he posted about shaving a bit of plastic to allow the knurled nut to thread a little higher up to avoid the gear
http://forum.seemecnc.com/viewtopic.php?f=35&t=1168
Posted: Wed Mar 27, 2013 12:21 pm
by cambo3d
ApacheXMD wrote:gabrielk had that issue too and he posted about shaving a bit of plastic to allow the knurled nut to thread a little higher up to avoid the gear
I saw that but i didn't want to sand that area down, i think its that length for a reason to help the filament from binding. I think beveling the gear is a better idea
Posted: Wed Mar 27, 2013 12:30 pm
by cambo3d
I got a little ambitious last night. Since my calibration prints were coming out ok, I'd try something more useful. The spool holder, not perfect but still gonna be put to use. http://www.thingiverse.com/thing:60750
what infill pattern would you have used for the base of the spool holder and how do i get rid of the blobs.
Posted: Wed Mar 27, 2013 12:54 pm
The print looks pretty good.
On the base it just looks like you are extruding too much plastic.
Posted: Wed Mar 27, 2013 2:00 pm
by cambo3d
Polygonhell wrote:The print looks pretty good.
do i just adjust flow rate, while its printing to reduce plastic? then change it back when the infill is done?
Posted: Wed Mar 27, 2013 2:29 pm
This is what I do to calibrate, print a single wall print adjust flow rate then verify with a 100% fill print.
http://forum.seemecnc.com/viewtopic.php ... 5452#p5452
Posted: Wed Mar 27, 2013 2:38 pm
by cambo3d
thanks!
Posted: Wed Mar 27, 2013 4:51 pm
Make sure you only use that for its intended purposes.
Posted: Wed Mar 27, 2013 9:33 pm
by cambo3d
Since i broke my lcd angle mount trying to take my defective seemecnc lcd off. I had to figure out an alternative way to mount it and still have access to the sd card slot.
here is my solution. Its not angled like I wanted but it works. SEEMECNC CAN I GET A REPLACEMENT ANGLE MOUNT, WITH MY REPLACEMENT LCD???
Posted: Wed Mar 27, 2013 9:40 pm
cambo3d and others, I HIGHLY recommend that you contact SeeMeCNC support directly and not make requests in posts. They do not monitor this forum on a daily basis. Simply check the member list and sort by last visit time and you will see what I mean. Even if they did visit everyday, the volume of posts would make it difficult for them to find requests like this. Email customer support!
Cheers,
Posted: Wed Mar 27, 2013 9:42 pm
by cambo3d
mhackney wrote:cambo3d and others, I HIGHLY recommend that you contact SeeMeCNC support directly and not make requests in posts. They do not monitor this forum on a daily basis. Simply check the member list and sort by last visit time and you will see what I mean. Even if they did visit everyday, the volume of posts would make it difficult for them to find requests like this. Email customer support!
Cheers,
I have micheal, just getting a little impatient waiting for a response. by the way, you got any of those 25mm fans yet? I wanna get one for my hotend
Posted: Wed Mar 27, 2013 9:55 pm
by cambo3d
Does anyone know if there is a fan output for cooling the rambo? I would like to get a fan to circulate air around my rambo board. I have the 1.1b board but the pictures on the wiki doesn't show this connector. its says fan-2 right next to it, so i'm assuming its for a rambo cooling fan or is it for a printing fan?(circled in red below)
edit: never mind, I think if found my answer i believe thats a cooling fan connector for cooling printed parts, not a connector for running a cooling fan for the rambo.
so i'll just run a cooling fan for the rambo off my 12v accessory fuse block.
Posted: Wed Mar 27, 2013 11:45 pm
by Flateric
Isn't there one on the lower right corner area of the board labelled 12v aux out?
Posted: Wed Mar 27, 2013 11:54 pm
by cambo3d
Flateric wrote:Isn't there one on the lower right corner area of the board labelled 12v aux out?
your absolutely right, i just checked, but they didnt include any headers for it. darn. rather than remove this thing to solder in one connector i'll just use my fuse block.
Posted: Thu Mar 28, 2013 11:33 am
I run mine directly off a spare 12V line from the PSU.
