Assembly manual discussion thread!
Re: Assembly manual discussion thread!
That edit was done last week or the week before.
Tonkabot wrote:
Jimustanguitar wrote:SNIP
Page 81. You should mention that the cheapskate carriages are not symmetrical a little earlier in the build. You mention this later with the eyes facing the right direction, but it's worth restating (or pre-stating) at each step. Especially before it's time to snap the carriage bases and t-nuts into the wooden piece without the eyes. My.. um... friend got this wrong the first time.
My 'friend' had the same problem, and now my CC eyes are backwards on all three cheapskates. I pounded all the T-nuts in with a hammer (light tapping works fine) and didn't really want to pry them out.
I would suggest laser printing some text saying this side up or in or something on the correct sides, but I saw pictures of an injection molded cheapskate, so going forward I suspect it will be a non-issue.
You should have monitored your friend better, perhaps try to talking to him while standing in front of a mirror. :)
dgriff
Post by dgriff »
Been doing some additional dialing-in and found that I had to set my ext1 steps per mm to 182.640 for it to feed precisely 1mm of filament out. Tested over 10, 30 and 100mm distances and it was consistent.
Any ideas why that might be the case over the recommended 92.65 in the documentation? Since it's almost precisely 2x the listed value, it seemed like something might be amiss somewhere?
dtgriscom
Post by dtgriscom »
(Just when you thought it was safe...)
Here's some more comments on the manual (everything validated on version 1.26):
  • Page 9: You might want to add "Additional 4" Cable Ties" to the optional list of materials needed; I used up the included 12 long before I finished (too many Barbies to handcuff, I guess).
  • Page 121: Section 13 is titled "Wiring & Installing the Hot End, Bowden Tube", but the hot end isn't actually installed until section 15 ("Installing the Hot End"). So perhaps a better title would be "Wiring and Assembling the Hot End, Bowden Tube".
  • Pages 128 and 235: As you tell people to tighten the large nut, you might want to tell people to NOT use pliers on the PEEK tube.
  • Page 133, typo in second sentence: "like a spring an can be opened"
  • Page 133: You should specify which way effector platform should be installed (with the SEEMECNC text pointing down, right?)
  • Page 137: move the Spool Arms from the list on this page to the list on page 141
  • Page 160; mention to the reader that all wires to the RAMBo should be routed out through the vertical support's center hole. Otherwise when the LCD is installed on page 173 the wires will get pinched.
  • Figure 18-19, page 163; it's a bit confusing that you have one set of connectors outlined in green, but a separate set of connectors labeled "X", "Y" and "Z". It might be better if you moved the labels to below the target connectors so they didn't match up with any wrong connectors
  • Page 167: Make sure to install the ribbon cables EXACTLY as shown, with the red edge towards the long end of the interface board, and with the ribbons coming off the correct side of the connectors. You'll have to figure out which end of each cable to use; only one will work.
  • Page 174: It would probably be a good idea to install some sort of strain relief on the USB cable to prevent yanking on and damaging the RAMBo USB connector.
  • Page 184: The download link for the Arduino IDE has changed, and is now http://arduino.cc/en/Main/Software. (Yes, your link is forwarded, but it may not always be, especially if they re-rearrange their website.)
  • Page 185: on the Mac, you'll want to use a serial port of the form "tty.usbmodemXXX". If you can't figure out which one to use, unplug your Rostock MAX, wait a couple of seconds, and then look at the choices in the Tools/Serial Port menu. Then plug in your Rostock MAX, wait a few more seconds, and then check the Tools/Serial Port menu again. One of the new items will be what you want; use the "tty." version rather than the "cu." version.
  • Page 188: you might have to navigate several folders deep before you find the file to uploaded.
  • Page 227: You recommend the Hansen Hobbies PDF on connectors, but it never shows how to install the pins in the BEC connectors (there's a right way and a wrong way). One place I found that does is http://www.micronwings.com/Products/JST ... ndex.shtml .
  • Page 235: You give some useful detail to assembling the hot end to the mounting plate in Appendix A; you might want to add that detail to the main text at p128.
As always, thanks for a great manual,
Dan
Tonkabot
Post by Tonkabot »
Oh, I was wondering what happened to chapter 22. Seems to be deleted or something.
dgriff wrote:Been doing some additional dialing-in and found that I had to set my ext1 steps per mm to 182.640 for it to feed precisely 1mm of filament out. Tested over 10, 30 and 100mm distances and it was consistent.
This is pretty normal. The exact diameter of the filament will vary, and so will how hard/soft the filament is. There also could be tolerances that vary between the springs used in the extruder, pressure required to push through the bowden tube, etc.
The fact that you measured a different value is evidence of your own thoroughness and not of a problem or quality control issue.
dtgriscom
Post by dtgriscom »
But, off by a factor of two? That isn't quality control, that's a mis-operation (for lack of a better word). Mis-control of the stepper motor? Wrong microstepping option (e.g. 8x versus 16x)? Lots of drag on the stepper causing it to be able to move only once every two steps? The calipers are completely whacked?
Strange...
Dan
I wasn't reading that closely :) Perhaps you have a motor with .09deg steps instead of 1.8?
Check the sticker on it.
OMW_Jun
Post by OMW_Jun »
I just got to printing the fan mounts linked in the latest assembly manual but download for the blower fan shroud doesn't contain a .stl, it may need to be re-uploaded. The peek fan mount printed great though!
dtgriscom
Post by dtgriscom »
OMW_Jun wrote:I just got to printing the fan mounts linked in the latest assembly manual but download for the blower fan shroud doesn't contain a .stl, it may need to be re-uploaded. The peek fan mount printed great though!
I also had trouble downloading the layer fan. There's a "Download" button at the bottom of the "johnoly99" column, with a reveal arrow next to it. If you click the button itself then you get a bad download (it seems to be some sort of zipped version of the web page structure?). However, if you click the reveal arrow, and then click the "Download" button that it reveals, then you get the proper zipped STL.
Confusing...
Dan
OMW_Jun
Post by OMW_Jun »
Confusing...
Dan
Here is the STL.
NEW2-Guanu-Blower-Fan-Holder-Shroud.STL
(146.18 KiB) Downloaded 696 times
guanu
SeeMeCNC Staff
Post by guanu »
stop hacking my computer eagle! (lol j/k)
Guanu
guanu wrote:stop hacking my computer eagle! (lol j/k)
Guanu
No way, make your computer hack proof if you can. Lots of luck! :)
Nylocke
Post by Nylocke »
Looks like eagle is a 1337 H4X0R, H4X me now :D
Nylocke wrote:Looks like eagle is a 1337 H4X0R, H4X me now :D
Could you say this once again, in English. I am not good at internet hieroglyphics.
rootboy
Post by rootboy »
Confusing...
Dan
Try this one:
http://repables.com/r/200/
The duct I specify is a better choice.
dtgriscom
Post by dtgriscom »
geneb wrote:The duct I specify is a better choice.
I don't doubt it, but it's strange that the main "Download" button is broken for the fan you point to, but works on the fan rootboy suggested. (A mistake while uploading?) You may want to note the downloading problem in the manual.
I also don't know how to contact whomever runs Repables.com to report the problem. There's no "About Us" link I can find, and the "Feedback" link leads to a blank page.
Very strange,
Dan
dtgriscom wrote: I also don't know how to contact whomever runs Repables.com to report the problem. There's no "About Us" link I can find, and the "Feedback" link leads to a blank page.
It's Evan from SeeMeCNC. Repables is their site, but it's not branded with their name all over it because they wanted anyone and everyone to use it.
The download issue is a new one - it worked when I originally downloaded the file. I'm not going to note what's likely a temporary issue in the manual.
Many edits were done today and I found Tonkabot's missing chapter. *Evil Laugh*
Nylocke
Post by Nylocke »
That was "looks like eagle is a leet (elite) haxor (hacker), hax (hack) me now :D (laughing face)"
You are one funny dude! I'm glad you're on the forum, you cheer me up now and then.
Pingel
Post by Pingel »
dtgriscom wrote: Page 133: You should specify which way effector platform should be installed (with the SEEMECNC text pointing down, right?)
How big of a problem is this? My nuts were spinning when I was trying to tighten the screw and I couldn't get in there very well with a wrench. After reading this I'm wondering if I mounted it upside down, I never saw anything that said SEEMECNC. I can check when I get home.
dtgriscom
Post by dtgriscom »
My guess is that it matters somewhat, and I guessed that the "SEEMECNC" embossing should point down.
I do remember using a socket wrench there, which may have made it easier.
(If I sound certain, then I'm not communicating very well ;) )
Dan
