Page 1 of 2
Re: Mach 4-Axis Board Configuration
Posted: Sun May 20, 2012 8:04 pm
by seemeadmin
SeeMeCNC user notes for the 4 axis HY-TB4DV-M 4 Driver Board.
This board is a common import and the manufacturer has some common problems. With only a little effort, you will find this a very reliable, powerful, and inexpensive control solution for your SeeMeCNC 3D Printer. This board makes SeeMeCNC machines the FASTEST available today!
There are no drivers, firmware, bootloaders, version concerns, etc. It's old school cool. Just plug into a desktop PC parallel port and begin.
Reference document about the 4 Axis Stepper Control Board:
SeeMeCNC_4axis_Stepper_Control_Board_HY-TB4DV-M.pdf
4 Axis Control Board LPT Notes HY-TB4DV-M
(125.77 KiB) Downloaded 2211 times
Copy the following XML file into your Mach3 installation folder. Right click, and extract. Close folder. Choose "Mach Loader" (should be on your desktop after download and install from Artsoft) and you will see this profile automagically listed. This will 'launch' Mach3 with all the right start up settings.
SeeMeCNC-H1-4Axis_extract_into_Mach3_folder.zip
Mach3 XML Profile for 4 Axis stepper control board_put into mach3 folder_setup for slic3r
(30.59 KiB) Downloaded 1766 times
If your motors go 'dead' when you reset the e-stop, check this: Following MHackney's post screen shots above, and specifically referring to the "OUTPUT SIGNALS" tab on the "PORT & PINS" dialog box, you might need to reverse the "Active Low" settings. We had to do this on one of our PC's at SeeMeCNC headquarters. If the 'enable' pin and "Active Low" settings on these outputs are reversed, the stepper will receive power during an "Emergency Stop". Then turn off when the E-Stop is reset. Simply open the "PORTS & PINS" and go to the "OUTPUT SIGNALS" tab. Then reverse the setting under "Active Low" for each "Enable 1, Enable 2, Enable 3, Enable 4).
ports-n-pins "active low" is usually 'X'
Setting your axis calibration is pretty easy. Don't feel overwhelmed at all the settings. However, you should refer to the Mach documentation.
Look right above the emergency stop reset button. "Set Steps per Unit". You will choose an axis, move a specified amount, measure, then enter actual distance moved. Mach will make adjustments to your motor tuning 'steps per' based on your data entry.
settings axis calibration screen
And a photo of the 4 axis stepper control board.
DIP SWITCHES IN THIS PHOTO ARE SET to go with the 'Mach-Loader' Profile above. The A axis for extruder (not spindle) is Slic3r ready! The photo also shows jumpers installed on a HY-TB4DV-M:
SeeMeCNC 4 Axis Controller HY-TB4DV-M   with jumpered optos
~PartDaddy~
Posted: Wed May 23, 2012 7:29 am
by Tony Woollacott
Fantastic, thanks very much.
Posted: Wed May 23, 2012 7:48 pm
by seemeadmin
Some Slic3r Profiles to get you printing:
http://forum.seemecnc.com/viewtopic.php?f=13&t=641
Posted: Fri Jun 01, 2012 10:31 am
by mtizle
Currently working on the jumpers settings for the 4 axis board. What did you use for the jumpers? Kinda looks like staples. Also wondering what the top jumper setting is, hard to see PIC attached.
Thanks for all your help,
Mtizle
Posted: Fri Jun 01, 2012 10:45 am
by mtizle
Looking at the 4 Axis board the 12v and Ground terminals have 3 wires connected. Just to make sure I have the correct wires connected they are as follows:
12V Terminal
1 from power supply
2 from Thermostat
Ground
1 from power supply
1 from Heat resistor (Hot end resistors)
1 Thermostat
Pic included
Thanks for any help,
Mtizle
Posted: Fri Jun 01, 2012 11:36 am
by johnoly99
Hey mitzle. John here. You will want to bring 3 yellow 12V lines from the PS and 3 black gnd lines from the PS to the 3 axis board. Run seperate power/ground lines from the PS to the heater board, this will help with any signal interference. The axis board can be "noisy" and running the lines from the PS seems to eliminate this. Also, your hot end resistors ground wire comes back down and doubles up on the thermostat boards ground wire. That's fine. And you should have a jumper from the thermostat board going into the COM (center lug) on the relay terminals, and then the NO terminal runs up to the other side of the heating resistors.
Posted: Fri Jun 01, 2012 11:52 am
by mtizle
Can you give me a visual example of this? Don't really understand the procedure. Took a look at the thermostat board and I think in my wiring diagram has it this way.
Mtizle
Posted: Fri Jun 01, 2012 1:16 pm
by mtizle
Created an updated Wire diagram for the 4 Axis board. Added jpg and pdf files. Wanted to add the visio file also but not allowed. Next will be the 4 axis Jumper and Dip switch settings. Edit Diagrams Verified.
Mtizle
Posted: Fri Jun 01, 2012 2:09 pm
by mtizle
4 Axis Board Dip switch and Jumper Settings Diagram. Settings were taken from photo found on this post by Seemecnc admin. Would it be alright to use solid core wire for the Jumpers? Looks like you used some kind of staple or solid core material. Edit - Diagrams Verified - Went ahead and used 22 gauge solid core wire for Jumpers, added a pic of my finished board with Dip and Jumper settings.
Mtizle
Posted: Sat Jun 02, 2012 11:43 pm
by mtizle
Anyone have a Motor Tuning profile for the Z axis? On the first page of this post are X, Y, and A but no Z.
Mtizle
Posted: Mon Jun 04, 2012 5:28 pm
Ok, Here is my Z Axis tuning. It's been working great for me.
cheers,
Posted: Mon Jun 04, 2012 5:33 pm
by mtizle
Thank you so much,
Mtizle
Posted: Tue Jun 05, 2012 5:52 pm
by mastercaster
Can we please have a mach3 setup and board swich setting post.. Official Post.
I know I should know everyones name, but at the moment I don't. So I don't know who to listen to.
The current posts don't seem to match. So PLEASE post an official setup in the document area, where the manuals are. It will releave the frustration.
Alan
Posted: Tue Jun 05, 2012 9:00 pm
Unfortunately, we can't post the Mach XML file here. I wrote the manuals and the configs in this thread that I posted are what I'll put in the 4 axis Electronics Manual. Just look at my screen shots at the start of the thread. I inadvertently left out the z motor tuning, that was posted yesterday.
Cheers,
Posted: Wed Jun 06, 2012 11:25 am
by mtizle
Mastercaster all diagrams posted by me have been verified to be working diagrams.
Mtizle
Posted: Thu Jun 07, 2012 3:36 pm
by PartDaddy
In my "SeeMeAdmin" post above (on top of second page), The Z and A axis dip switches should be set the same, for 1/8 stepping. X and Y are set for 16th microstepping.
Posted: Thu Jun 07, 2012 8:35 pm
by mastercaster
Yup.
Went over the settings very carefully and used the slic3r settings for 3mm,.02 yoda. A little fiddling and WOW. fantstic prints on Plexiglass with ABS.. Hard to belive the print quality. Thanks for a great product.
Only thing we need is some kind of good feed system. The machine needs a little tending cause the filiment tends to jump over each other and jam.. But with a little tending no real problems.
Alan
Posted: Wed Jun 13, 2012 3:28 pm
by mtizle
Below are my Motor Tuning Profiles. They turned out to be double of that of mhackney's configs. I also had to reverse the motor direction for the correct + and - direction.
Mtizle
Posted: Wed Jun 13, 2012 8:35 pm
You probably have your 34 Axis board configured for a different micro step than I do, that's why your steps per are doubled. I think I have mine configured for 1/8 stepping. How is yours configured?
Cheers,
Posted: Thu Jun 14, 2012 12:15 pm
by mtizle
No idea what the stepping is... is that configured on the board by the jumpers? My jumper settings came from Steve's with Seemecnc. So you think it could be set to 1/16 micro step right now?
Mtile
Posted: Thu Jun 14, 2012 12:27 pm
by johnoly99
Tizle, yeah, the board you looked at up in the lobby was 1/16 stepping.
Posted: Mon Dec 31, 2012 1:33 pm
by pwaisberg
Hi,
I am curious if anyone installed limit switches? Do you have photos or diagrams? Thanks!
Posted: Wed Apr 03, 2013 6:37 pm
by Jojo
Hello
I am new to seemecnc and I have a quick question that I hope you guys can help me with. I have had a 4 axis board for a while now and I think it may be an older one because everything looks the same except my dip switch only have 2 switches per box instead of 6 as shown in your pictures. Will this affect the jumper fix? Thanks in advance.
