printer calibration for eris 3d printer how to
how can i calibrate my eris 3d printer?  no method that i tried worked and i can print nothing for  some long days.
				Qdeathstar
Re: printer calibration for eris 3d printer how to
I would contact seemecnc support.. I don't think the auto calibration feature works too well, based on what I've read.. Some people who actually have it have given up on the auto calibration all together..
Yes it can be manually calibrated through changing the endstop settings in the eeprom. I print a 5 inch diameter circle, and measure it at each tower location.  For leveling, I would not adjust the Y tower offset, just the X and Z.  I would take the measurement of say the X tower, and compare it to the Y tower. The difference in mm will be divided by .0125 to determine the number of steps to add, or subtract to the X tower offset.  I would then do the same for Z.  I have a lcd display installed on my Eris, so I can calibrate the Z height from the display,,,, As you may not have that option, Once you have your bed "leveled", you would then add, or subtract steps to all three tower offset settings to adjust your Z height.
Good luck.
							Good luck.
thank you for your advice . Have a good day!
